Canon IR8500 Fuser upper roller has a bit missing all the way around about 1/4 " wide. I have no idea at this point what caused the ring of missing material around the roller. It prints but leaves a stripe of toner that is not fused and rubs off. Do I need to replace the fuser unit, the roller, or something else?
SOURCE: IMAGERUNNER C3200N PRINTED DOCUMENTS LOOKS YELLOWISH
ok if you are getting peices of rubber on the pabe it could be the fuser rollers.. this unit comes out easy.. looking at the unit there are 2 screws on both ends looking back at you... remove the screws and the unit lifts strait up once its out you can see the rollers much better. it is either comming apart or the teflon could be sliding off. if it looks ok you may need to run the paper thru slower it may not be fusing good 2 ways to do it try the bypass and select heavy 1 or you can set the cassette for heavy under add func common settings paper settings...
SOURCE: Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
SOURCE: Canon 3220 toner streaking/ghost image
It might be afixing problem, but did you try to replace ITB cleaning blade?Its hard to say without seeing a copy/ test sheet
SOURCE: repeating white spot deletion suggests drum, fuser
Fuser doesnt sound like your problem generally speaking fusers will add black marks not deletions look to your image creation lense mirrors erase lamps or defective charge grid
SOURCE: replacing upper fuser roller
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
