Question about NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter
Not enough resource
I have Compaq notebook (Presario 2175US) and I cannot get this PCMCIA card to work. Windows complains there's not enough resource for it to work. Any ideas?
0 characters
1 Points
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Feb 01, 2009 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
USB adpater not working? Might be insufficient power
Background. I have a few older laptops with USB 1.1 built in and I wanted the faster speed of USB 2.
This was my 3rd PCCARD USB adapter, the prior 2 did not work either. Again, the PCCARD USB adapter did not work in 3 different laptops. I could not even read a flash memory stick. grrr
Turned out the problem was the laptops were not able to supply enough power to the card. When I plugged in a 5v wall wart into the worked...I could read the flash memory stick. So, it appears that some of the older laptops just can't supply enough juice to the card.
This seems odd as on one of the laptops, I use an external CD drive with an attached PCCARD adapter, and it gets its power from the PCCARD.
on Jul 13, 2008 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Stop 7
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
Aug 05, 2008 | Ricoh R5CA475 PCMCIA to PCI Interface Card...
External hard disk and pcmcia cardbus
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Your problem is a power overload on the USB 2.0 card. If you plug in a 5volt power supply to the USB 2.0 PCM/CIA card, it will solve your problem. You can also use any USB port on your computer to plug in an A-A USB cable to power the PCM/CIA card and it should resolve the lockup. Also, check and make sure you have enough RAM memory in your comptuer for Windows XP. Recommend 512, but runs much better on 1024 (1 gig) of RAM.
May 10, 2008 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Freezes Win XP
i would go to your notebook manufacturers web site and download the latest pcmcia driver as it's obviously the driver thats causing the freezing.
Sep 03, 2007 | HP (PM453A) Serial Adapter
Windows doesn't detect the adapter
may there is realy a defect on that card. just try use another card and see the result.
Aug 13, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Techgear 3-port 1394 FireWire CardBus
Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
Machine locks up
install the vendor specifig driver for the PCMCIA. because windows XP sp2 is also able to detect the device and when you push the device online it is detecting and there is some other device which has got same IRQ and that is conflict with this and stop. see any error that is generated in event viwer * run>type "eventvwr" and enter * see the application/system try to detect your error log and see what microsoft says about it. otherwise post the error report Thanks Arun
Jan 17, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter Logo
29 people viewed this question
Top NEC Serial Adapters Experts
Martin Murray
Are you a NEC Serial Adapter Expert? Answer questions, earn points and help others
