Question about Siemens WXL142 Front Load Washer
Will not stop washing!
Siemens XLS 140 worked fine for 2 years. Moved to a new address and now it will not move off the wash cycle automatically. All functions appear to work if I move the control knob onto a new setting eg rinse, pump, spin. Switch on a wash cycle and the machine fills normally. Auto load balancing occurs. A target time is set. But then it just keeps washing! If I move it to spin, it says "machine too full". Move it to drain, and all the water is removed. I have not detected any problems in the fill hoses. The drain filter seems to be clean, although I have not looked other than at "ground level" behind the trap door. The pressure switch works if I blow into it, but presumably the other pressure sensor is used to detect the level by varying its output voltage, so cannot easily be checked (although I could try). I cannot see any loose wires, but I have not removed the front panel.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: washer spins dry but will not fill also outer tub does not drain
If washer does not fill.
If water is not getting into the machine, check the following:
To start cut power to the applianc3e for five minutes, this can fix a jammed timer control.
Check if the hot and cold water faucets are connected, and have good pressure.
If that does not work you may need to call a repairman to test the following:
The inlet valve must be tested by energizing it , testing valve solenoid, and reading voltages to identify a fault in wiring (contact).
If the inlet valve is fine when tested, worth having a look at the water level switch, if it is stuck on overfill position , it will prevent water from getting into the machine.
Lastly,the timer control board should be tested, to ensure that the problem is not a faulty timer keeping the inlet valve on close position.
Posted on Mar 30, 2009
SOURCE: my siemens WD1252 doesn't change from wash to rinse
Hallo,
I have the same problem since yesterday. I've seen that probably it doesn't warm up the water. If I change washing temperature to "cold" everything works normally. I think that heater is broken.
Have You resolved your problem? Have You called service?
Best regards.
Bartosz
Posted on Jun 13, 2010
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
My Siemens extraklasse xls140 isnt always doing the final spin and the water doesn't appear to be getting hot during the wash.
I have a siemens ekstraklasse xls 140 and at the stadge it must spin and drain it says drain is blocked. Is there any way i can unblock it myself and where do i find it.
Jan 27, 2011 | Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
Siemens WXL142 Front Load Washer Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
