Question about Refrigerators
Ice build up in bottom of freezer
There is a thick layer of ice in the bottom of my freezer compartment, now all the way to from the back to the front by the door opening. I also have ice on the refrigerator side of the wall in between the freezer and refrigerator. Maytag side by side model #MSB2354ARW
    Scholar:
  • 66 Answers
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Posted on Nov 16, 2008
  • Charles Caldwell Nov 18, 2008
    If my answer was helpfull to you Well you please rate me.
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
Layer of ice builds up on bottom of freezer
A common cause on many refrigerators is the the aut-defrost drain hose is plugged resulting in a back-up and depositting in freezer compartment. Check the drain pan under the fridge, if it is dry, then check the drain hose for blockage.
Gabe
Aug 01, 2011 | Kenmore 72282 / 72284 / 72289 Bottom...
I have a beaumark refrigerator with a freezer at the bottom. The freezer keeps filling with a thick layer of ice on the bottom of it. I defrosted it 10 days ago and the build up is already so bad that...
this could be one of two things,,, the thermostat has failed or it could be the door is not shuting up tight if the door seal is letting warm air in that will cause the ice build up you getting, ,so will that thermostat if its running flat out all day, look at the door first, then try turning down the stat,
Nov 10, 2009 | Refrigerators
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerators Logo
582 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
