Question about Sharp Aquos LC-32D40U Television
Sharp LC-37D4U, the monitor doesn't turn on
Hi, I have a Sharp Aquos LC-37D4U, the problem is: the monitor doesn't want to turn on and the power light (blue) blink 3 times , then stop for 2 seconds and blink again 3 times, and keep doing that. Also the green light (opc/dl) blink 1 time, stop for 4 seconds, and blink again, and keep doing that. When I try to turn off the TV it doesn't want to do it, so I have to unplug it. I want to know which module is not working to replace it. Thanks
  • Sharp Master
  • 1,830 Answers
It is hard to say without first looking at it.
Posted on Jun 28, 2017
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
  • 53 Answers
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Posted on Jun 09, 2009
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
Blue Grey Horizontal lines across Sharp LC37D40U top 3/4 of screen
could be the Tcon (logic Board) thats usually the cause of lines
Feb 20, 2012 | Sharp Aquos LC-37D4U 37 in. LCD Television
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp aquos lc 37d62u will not power on; the power light flashes 4 times, pauses and then repeats the 4 flashes. Does anyone know what this error code means? Thanks!
It is detecting shorted circuits or power supply problem, need in-depth troubleshooting. Inspect the power supply module first for any sign of bad caps with domed tops, DC output voltage readings check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Mar 28, 2011 | Sharp Aquos LC-37D4U 37 in. LCD Television
Sharp LC-37D4U - Unit not power ON when power button is activated. - Main power module in located in the center has power (165V DC) and outputs 5V DC to the main processor module on the right via CN5702...
You have standby 5vdc but you need to find out if the processor board is sending out the PS_ON to the power supply to turn on the 12 and 24vdc power supply section.
Heres is the service manual and training manual for your TV.
Please see my basic troubleshooting guide here:
Capacitors kit:
Aug 07, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
LC-37D4U TV sharp aquos
Sorry, the only reason I have tv and video listed on my expertice is becouse of remote controls, people post them sometimes under wrong things so I add the whole thing to get the most problems.
ask another expert, use the find experts link on the front page, slinteriors should be able to help ya
Sep 17, 2008 | Sharp LC-37D4U 37 in. LCD Television
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
104 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
