Question about Whirlpool LEB6200 Electric Dryer
Dryer not heating or turning off
The dryer turns on ok but does not heat up and does not turn off at the end of the cycle it just keeps going. Is this 2 different problems?
  • 1 more comment
  • bgalindro Nov 16, 2008
    I have a Whirpool Model No: LCE5000PQ0
  • initbennetts Dec 15, 2008
    dryer is not heating up
  • Anonymous Feb 17, 2009
    I have the same problem. Any assistance?
    Scholar:
  • 31 Answers
It can be multiple problems. First are you using it on sensor dry or timed dry? If it is timed try, it's possible your timer is not advancing. If you are using sensor dry it could be your sensor.
To test the timer, check for continuity across the timer. If it is open, replace the timer.
To test sensor, run the dryer on sensor with nothing in it, if the timer advances quickly, the sensor is not the issue. If it does not advnace, it could be the sensor.
The no heat issue; check to make sure you don't have a blockage in the venting or in the dryer. If there is no blockage, check your element. To check if the element is not heating up, check for continuity through the sensor.
Hope that helps.
Posted on Feb 12, 2009
Hi, i have a whirlpool duet sport wfw8400tw03. When i run to normal cycle, it stop no error code no light. The washing machine just shut down. I can run it on delicate or sanitary.Is a balance trouble
if u can run it on delicate or fluff cycle with cool air more than likely its ur cycling thermostat or the hi limit thermostat going defective test it with a meter for ohms..
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
HI LIMIT THERMOSTAT DEFECTIVE? SHOULD SHOW OHMS AT ROOM TEMPERATURE
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Whirlpool Kenmore Dryer Won Heat Test Replace Heating Element 279838
Apr 17, 2017 | Whirlpool Washing Machines
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 19, 2015 | Maytag Dryers
Have a gas dryer ..with. A burner high limit fault . Sign... Runs for 2 seconds and turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 19, 2015 | Dryers
I have a Samsung DV330AEB XAA 04 dryer. It has been turning off during loads on high heat timed dry. Any ideas as to why?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Nov 19, 2014 | Samsung Dryers
Kenmore stack washer/dryer model 417.93802200 the dryer keeps turning off before cycle is finished
GOD IS GOOD !!!!
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 02, 2014 | Dryers
Dryer will run about 10 minutes then shut off. Try to turn it back on and it just will buzz
Either a motor with bad windings,. or an over heating problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
GOD IS GOOD !!!!
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 30, 2014 | Dryers
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Jun 22, 2014 | Kenmore Dryers
Why dose a electric kenmore dryer 70 seires the dryer runs about 1minute then turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Dryer drum turns, heats, but then heat shuts off before timer has finished.
The heat is supposed to turn off ten to fifteen minutes before the end of the cycle. It's a cool down period.
Jan 08, 2014 | GE Profile DPSB613G Gas Dryer
NO HEAT FRON DRYER , DRUM OK
either your heating element,hi-limit switch,cycling heat switch, thermistor,control panel, or you don't have 240 volts supplying the dryer,120volts will still let the drum turn or the timer count-down, its the way there wired
Nov 01, 2009 | Dryers
Whirlpool LEB6200 Electric Dryer Logo
332 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
