Question about GE WSXH208A Front Load Washer
Same prob-GE front: drum rotated during wash, but did not drain.
I took the panel from the bottom off...however, not sure which hose to take out...I can feel the coins, and other stuff on the BIG hose...Also beside the hose....do I need to clean any other place?
The BIG hose attached to the drum, and the motor and the little hose attached to the motor and extend out to the washer machine to drain.
It appears I can remove the BIG hose...with some type of screw...not sure how...however, the small hose uses a different clams...not sure if I can put it back together...do I need a special tools or I would not need to take that apart?
I am new at this...just too expensive to call a repair person, any help I really much appreciate...Thank you! Please help.
    Scholar:
  • 131 Answers
All you need to worry about is the big hose(this the pump inlet)your gonna want to loosen the clamp at the pump(you will need a screwdriver or 5/16 nutdriver) once this is loose,remove the hose with a twisting motion.now clean it out & put it back together.all there is to it.hope this helps.thanx for using fix-ya.please rate all replys.
Posted on Nov 16, 2008
  • 1,543 Answers
Most of the time the hoses are attached with spring clamps. Just use a pliers to squeeze them together to allow you to remove them. Take off both hoses. Scoop out as much water as you can first. You may want to pull the machine forward about two feet and then tilt it back to the wall to prevent remaining water from spilling. Pump is only held down by two screws. Take them out and inspect the pump for obstructions and remove coins and other objects from the big hose.
You can do it.
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
It keeps on pausing during the cycles, what do I do to stop that?
It sounds like your Door Switch assembly may be faulty. During the cycles, the machine thinks the door is open, so it pauses the cycle.
Can you hear the machine drain? If not, this could be a Drain Pump problem, or Drain filter problem. You will need to remove the panel to access the Drain pump at the bottom of the machine. Remove the Drain pump hoses and clear them out. Make sure your Drain pump is also clear and turns freely.
Does the machine's drum spin? If not, you may have a Motor or Motor control board problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 28, 2011 | GE WSXH208A Front Load Washer
GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Nov 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
Jun 11, 2009 | GE WSXH208A Front Load Washer
Not spinning
If the m/c is washing but not spinning, then u need to check the filter.
It is located behind the lower rear panel of m/c.
Remove panel and remove large black hose on the bottom of drum, there u will see the filter, remove and clean.
Refit and make sure the hose is on properly.Test.
If u have no drum action on wash or spin then u need to check the motor carbons, this can be done whilst u have the rear panel off.
If carbs o/k but still no motor action, then u prob have control board prob.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Hotpoint First Edition WMA12 Front Load...
GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Dec 10, 2008 | GE WJSE3110A Top Load Washer
GE Washer won't spin
I believe your problem is a clogged drain hose.  If the pump can't pump anything out of the tub during the spin cycle, the machine doesn't complete the cycle.  Using a phillips head screwdriver, unscrew the three screws across the bottom of the machine, just above floor level.  Remove the panel and look for the 2" drain plug on the right - it's white plastic.  Now, if you have a shop vac, get it out and get ready to **** up all the water that drains out of the tube when you remove the plug.  Alternatively, you can use a bunch of towels.  More than a gallon will come out.  Clean any of the **** out of the screen attached to the drain plug and look for any debris in the tube in which the plug screws into.  This should fixya.
Oct 21, 2008 | GE Energy Star WCVH6260F Front Load Washer
Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WSXH208A Front Load Washer Logo
73 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
