Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop - Can't connect to internet
I have the above computer with a Comcast modem and Linksys Wireless B 2.4 GHz broadband router. When I attempt to get online, I receive the following message: "IE cannot display the webpage - most likely causes (i) you are not connected to internet, (ii) the website is encountering problems, (iii) typing error." It's clear I'm not connected to the internet. It seems that the modem and router work as I can get online from a laptop using the router. As such, I believe the issue is with my desktop. I've skipped the router to go directly from the modem to the desktop. I've also pulled out another ethernet cord. No luck. Any other thoughts? Thanks!
  • TenneT Nov 16, 2008
    Seems my Network Adapter had somehow been disabled. To fix, I went to My Computer --> Properties --> Hardware --> Device Manager --> Network Adapters and then re-enabled it by clicking on the X next to Broadcom. Thanks for all the help!
  • May 11, 2010
    What operating system is running? It sounds like some of the parts needed for networking are missing or corrupt. They can usually be reinstalled without too much trouble.
    If this is a problem that started recently and you have System Restore available, you might try restoring to a date when networking was working properly.
How do i connect my Westell router
Posted on Jul 09, 2009
  • Dell Master
  • 998 Answers
The NIC (network interface card) is integrated into the motherboard of the 2400 computer. Most likely that circuit is bad. To fix it you’ll have to replace the motherboard or purchase a NIC card and install it into one of the PCI slots on the motherboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 16, 2008
I am trying to put comcast internet on my comp and it wont conect it keeps trying to use dial up instead of broadband
Hello
Is the ethernet line from the router plugged into the ethernet card on the back of the pc?
Not the phone line.That needs to be in the modem.
Apr 28, 2011 | Dell Dimension 2400 PC Desktop
Can't get router to connect to Dell Dimension 2400 desktop
Try turning OFF DHCP from services. This may fix your problem. Look for "DHCP Client", double click on it (or right click and choose properties), STOP the service, then set it's startup type to 'manual'. That'll kill it. See DHCP is what "Gives out/assigns addresses" and on the ONLY PC, it is the First one... 192.168.0.1... Both PC's will be assigning themselves as that, and that will cause a conflict. As the Router now does the DHCP work. Of course ensure you DO have DHCP set on router.
Feb 12, 2010 | Dell Dimension 2400 PC Desktop
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 4700C Desktop PC, internet issue.
Try and test the computer and modem connection by hooking it up directly by an ethernet cable..
If the internet connection stays solid when cabled up..
Then try either changing or removing the wep or wpa encryption on your wireless network, and seeing if that allows the computer to stay connected.
Also try disabling the firewall on your computer, and also on your modem.
Oct 30, 2009 | Dell Dimension 4700C PC Desktop
Dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Mar 30, 2009 | Dell Dimension 2400 PC Desktop
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Dec 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Dell Dimension 2400 PC Desktop Logo
1,664 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
