Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
We have a Whirlpool Quiet Partner II that was being noisy and then it stopped washing the dishes. We took it apart and found a nutshell in it but now it is still not going through the wash cycle. We have noticed when we start the dishwasher on a normal wash cycle that the LED light for sensing doesnt light up. Does that have anything to do with the dishwasher not washing?
When started it goes right to washing and then fills up with water and stops. It is model number DU1015.
  • 1 more comment
  • lynloo62 Nov 21, 2008
    Had same problem about 1 1/2 yrs ago. Repairman said was sensor so we had it replaced. Now same thing has occurred again. This was preceded by a noisy machine a week or so before it stopped washing. I can get a fault code of D3-05-16 but cant find anywhere that tells me how to repair.
    You can check you machine to get a fault code by touching these buttons:
    Heated dry, then Normal, then Heated dry, then Normal again. A code will flash in 3 sets of double digits. The first set may have letter and/or number. My code is D3 05 16.
    I would like to know what this means so I can be sure the repairman is ripping me off or if I need to just buy another dishwasher since this is the 2nd time in a short period this has occurred and the dishwasher was just bought 5/18/06.
  • acidblues500 Dec 11, 2008
    I wish I could help, but I too have a similar problem with my Whirlpool Quiet Partner II. I dropped some pistachio shells inside the machine, and can't get down to the food grinder. It would be helpful if anyone with previous experience can chime in with some assistance.
  • Anonymous Mar 18, 2014
    I get a E:02 message at end of wash cycle. Dry cycle does not seem to get hot.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
My Quiet Partner III dish washer gets very noisy while filling up with water at beginning of rinse or normal wash cycle. That noise lasts for about 1 minute upon starting only. Would it be a faulty...
yes its a bad inlet valve. sometimes you can turn down the house valve the washer is connected to a little to stop the noise.othe then that replace the inlet valve.
Feb 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner 1 is extremely loud. I high pitch whine while washing. I took it apart and there is nothing clogging the system. any ideas?
I have the same problem. Same dishwasher with the exact problem. Took it apart...nothing clogged...maybe motor is going out on it. Still cleans the dishes though.
Any thoughts anyone?
Feb 10, 2010 | Dishwashers
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
2,370 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
