Question about Liquid Video A170E101 Monitor
Screen refresh is "jerky" when scrolling
I have tried searching for a driver that works. This monitor was included with a desktop from dell. It's fine until I start scrolling, then it really hesitates. I even tried messing with the setting to no avail (contrast, brightness, etc...) couldn't find a control for refresh rate. thanks, jp
  • dgruther Oct 16, 2008
    same issue my monitor is a e177fp from dell
  • Anonymous Mar 30, 2014
    when i try to scroll up or down,the scrolling won't stop, it just keeps scrolling.it does this whether i use the mouse or the up down keys. I have a Dell.
  • 624 Answers
The refresh rate for LCDs is 60 MHZ, your problem is very likly a video card driver issue. Unless you've changed the cards you should be able to download the correct driver direct from support.dell.com.
Posted on Nov 29, 2006
All across the screen a lot of black colored dashes are appearing. everything is fine but these dashes doesn't look good
Try selecting Auto Adjust from the monitor's on screen display. Should be accessible from the buttons on the front of the monitor.
Also try downloading and using the latest drivers for the monitor.
Also try checking the monitor's technical specifications and making sure that the refresh rate on the computer is set to the optimal refresh rate per the monitor's manufacturer.
Jun 21, 2011 | Computers & Internet
Tip
Video driver problem - black screen
My Dell Inspiron 530 (running Vista) started having video problems. (After working fine for months).  It would boot and let me log in, and would display the desktop for a moment, then the desktop would refresh, the screen would go black, and my Viewsonic VG 150 LCD monitor would display an error "Out of Range".
"Out of Range" error means "I am getting a signal, but it's not a signal that I recognize so I can't display the image".
It would boot correctly in Safe Mode, and also in 640*480 resolution.  But it would not work in 1024*768 resolution (the native resolution of this LCD).
I noticed that Microsoft Update had, the night before, installed an Optional update to the Intel onboard video controller driver.  The driver was dated Feb 2008 and that is the latest from Intel, so I don't understand why it installed a new update in April 2009 (?).
I ran the Dell diagnostics on the video hardware and I did notice that in one sequence of about 15 screens that flashed quickly, two of them displayed the Out of Range error. So clearly the Intel video hardware is able to generate a mode that this monitor cannot handle.
My best guess is that something about the automatic Update of the driver is what broke this installation.
I removed the Intel driver (in Device Manager.. Display Adapters), so Vista fell back to its generic video driver, and the problem went away... I can select 1024*768 resolution and it boots fine.
I haven't yet attempted to reinstall the Intel driver (I'm just happy to have it working again).
on Apr 20, 2009 | Dell Inspiron 530 Desktop Computer
Scrolling is very jerky. This is after a Windows XP re-install.
try changing the refresh rate , or install the drivers that came along with your monitor it will solve the problem.
Jul 03, 2010 | Dell E193FP 19" LCD Monitor
Dell laptop monitor jumping
Could be your refresh rate. Try the following:
* change your monitors refresh rate to higher availible.
* rt click on desktop then on properties and then display setting and then advance and then click on monitor tab and choose the highest availible and then click ok.
Would also attempt to move the screen forward and back to see if you have a pinched cable.
Also attempt to connect to an external monitor to see if it is your laptop monitor or the video card causing the problem.
Hope this helps.
Oct 25, 2009 | Dell Vostro 1510 Laptop
The sentences on my PC display screen move in wavy fashion from below upwards. It Dell screen and has been working well for the last two years.I down loaded Registry Mechanic of PC Tool. How to rectify?...
Have you tried to increase the screen's refresh rate? If you see some sort of blurring horizontal line that scrolls upwards, most of the time is that screen's refresh rate in your Display Settings are too low.
Jun 29, 2009 | Dell Computers & Internet
HP Pavilion will not work with Dell monitor
it's not referring to the monitor, the hard drive is the problem. maybe driver only.
May 10, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Mar 06, 2009 | LG W2252TQ Monitor
Raedon DDR video card
Check that you have installed the correct driver for your model video card and the correct OS version.
To check that the video card and driver is working, you may have to boot up in Safe Mode, go to Control Paned - System - Click on Hardware Tab - Click on Device Manager button - scroll down the list and if you see a yellow ? against the video then there is a problem with the video driver.
The problem could be that the refresh rate for the monitor is too high for the monitor to handle.
Boot up your computer and press F8 and then run in Safe Mode, go to Control Panel - Display - click on Settings Tab - click on Advance the Monitor Tab and change the refresh rate to 75Hz or lower.
Reboot again
Sep 02, 2008 | Dell OptiPlex GX110 PC Desktop
DELL DIMENSION 2350
the problem can be from  the video card or from  the monitor.for the monitor go to the officila dell site..there you can  find all the drivers you need..and for the video card instal a new propper driver..
if all this doesnt work..well contact a specialized Dell service..
bye
Feb 03, 2008 | Dell Dimension 2350 PC Desktop
Out of focus/fuzzy
Your screen refresh rate may be too high for the monitor or one of the parts might be incompatible with windows try lowering your screen refresh rate. Or checking windows for a compatible driver for the chip or monitor.
Feb 09, 2007 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Liquid Video A170E101 Monitor Logo
912 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
