Question about Kitchen Ranges
Kitchen aid range heats up too slowly
Lower element not working - fuse is good - do the elements themselves go very often or is there something else i could/should check ???
kitchen aid superba glass top self cleaning - 15 years old
thx in advance
Larry
  • Anonymous Mar 30, 2014
    My kitchen aid superba range model#ykerc507hw2 is 12 years old. The one element which has a dual control for a small burner and a large burner which is operated by the same control. The burner control is located on the bottom left hand side of the control panel. I think it is the switch on the control panel that is faulty. I have been trying to find the correct part for this model but what comes up is a part for an older model. Can you help ?
  • 370 Answers
Take the element out and check the ohms on the element. Replacing the element will fix you up.
Posted on Nov 18, 2008
Why are both the upper and lower elements of my Kitchen Aid oven not heating?
They are either both bad, there is a connection loose or you through a breaker. Check the breaker box first and that the unit is still plugged in. Then check the elements. If they are black and charred looking then they have burned out.
Mar 15, 2015 | KitchenAid Kitchen Aid KERS507X Electric...
My kitchen aid "superba " convection oven is not maintaining it's temperature. It has only one heating element on top.
There is a good chance there is a hidden element on the bottom. This is common on higher end ranges. It could be a bad element.
Sep 28, 2014 | Kitchen Ranges
New heating element pops circuit breaker
Obviously something is shorting out. Check all wiring.
Oct 31, 2017 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whirlpool elec. Single built in oven...lower element wont heat at all upper gets warm doesnt seem to get real hot. Metered lower element got continuity.metered wires to element nothing... Please help I'm...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | GE JGBP26 Gas Kitchen Range
How do i change the lower heating element in my oven?
74004107 - ELEMENT, BAKE (LOWER)
disconnect unit from power.
remove screws from lower element.
slide old element straight back slowly towards you so the wires follow it through the holes.
as you disconnect the wires from the old element either give them a bit of a bend so they do not slide back through the hole and get lost or immediately hook them onto the new element that you could sit below the old element for transferal of wires.
make sure wires are attached securely and reinstall.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Heating element
Give me the complete model # from the sticker on the range so I can assist you.
Oct 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
176 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
