Question about Whirlpool LER5636P Electric Dryer
Heavy duty cycle no heat
There is no heat only in the heavy duty cycle.
  • 370 Answers
IF there is heat on every other cycle you have a bad timer. Replace the timer and that should fix ya up.
Posted on Nov 18, 2008
5 Suggested Answers
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
  • 93 Answers
SOURCE: my frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Posted on Mar 15, 2009
  • 2699 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
Why does it work in all cycles except heavy duty?
I think I answered this before. Get an electrician to check the motor windings etc to see if there is a problem under load.
Feb 17, 2016 | Washing Machines
The Heavy Duty and the Daily Cycle lights are
to better assist you can you provide me with the ERROR code, if is any.
Thank you
May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Kenmore heavy duty clothes dryer will not heat
Feb 25, 2009 | Kenmore Dryers
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Whirlpool LER5636P Electric Dryer Logo
203 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
