Question about Maytag Dryers
How to open the dryer to see if the belt is broken.
    Scholar:
  • 66 Answers
Ther are a few ways to access the inside of the dryer that depends on brand and model number. What is the model number?
Posted on Nov 16, 2008
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Hotpoint dryer won't stay on
The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
Apr 27, 2013 | Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Pluged in push star says its working not working
you will need to open the dryer up and see if the belt is off or broken:
opening up a dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagram:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 26, 2011 | Dryers
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
Belt broken
how to open a dryer:
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Jan 10, 2011 | Whirlpool Dryers
Broken belt for clothes dryer LG
Remove the front panel .. two screws probably.
Look for the belt tensioner on the floor when you get it open.
Mar 28, 2010 | Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
Dryer will not turn on
most of the dryer when the belt break the dryer will no longer run open the door manually turn the barrel if it moves frely the belt is broken there is a switch connected under the belt tensioner causing the machine not to start if the belt is broken thanks from gilles
Mar 14, 2009 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
