Flame is too high after we changed the wick
I have a Dynaglo heater , that we changed the wick and the flames is too high . all the measures are what the book advises
The wick needs to be reinstalled in the raised position
Posted on Nov 17, 2008
How do I get my furnace to stop smoking and make my burner flame turn blue
This is an oil heater with a wick, or an oil furnace?
Wick
If it smokes the wick is too high and the burner is not burning all the gases produced by the hot oil in the wick.
Use the wick trimming tool and then relight it. Light the wick and then lower the flame until it is blue.
Furnace
With a furnace, you need to open the front, clean out any soot and clean the spinner in the middle. You may need to regulate the air mix intake to get a blue flame. If it is yellow, you need more air.
If it's gas, you need an engineer.
Feb 01, 2016 | Heating & Cooling
How high should the flame be in a kerosine heater
Adjust wick till nice Blue Flame, if wick to High flame turns White/Yellow. Turn down wick till Nice Blue Colour
Jan 11, 2016 | Heating & Cooling
Black smoke coming kerosene
hi dear,
First of all make sure that the heater is filled with K-1 Kerosene. Other fuel, such as gasoline, home heating oil, etc. do not burn hot, causing the heater to burn out of control. NEVER USE GASOLINE or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 Kerosene. If you are sure of your kerosene and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure your heater is not in a draft. Too much air can create a very high flame condition. Avoid placing the heater in drafty areas or under a ceiling fan. Make sure the burner chimney is seated correctly. If the burner chimney didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be raised too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned, or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact wick height. If the wick is installed correctly and there is no other obvious defect it is best to take the heater to a service center to determine the cause. Our Find a Retailer tool can be used to help find a servicing center.
Jan 04, 2014 | Corona 23-DK Compact Heater
Changed wick in corona 23dk , now has very high flame and smokes like crazy.
the wick is round in this heater and may have to be cut for height. should be about an eigth of an inch below the top
Jan 11, 2010 | Corona 23-DK Compact Heater
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
Only half of the wicks burns/ flame varies in height/ smokes !
Sounds like you have a wick that has burnt unevenly in the past and now there is not a good setting for an optimum burn. Either the wick needs to be trimmed even or you need a new wick.
Nov 14, 2008 | Heating & Cooling
Burns unevenly and smokes
try emptying your heater of fuel,and lighting it letting burn for several hours. This will burn all of the deposits off of the wick. Make sure your heater is outside when you do this. when done lower the wick,fill with fuel,and let the wick soak for fifteen minutes before lighting.If this doesn't work try brushing the top of the wick a light brush of some sort and light.If still no luck,change the wick.
Oct 01, 2008 | Corona 23-DK Compact Heater
High flame on 23-DK
Try opening the little door on the front and grabbing the metal spring like piece inside,moving it back and forth until it seats correctly.
Aug 12, 2008 | Corona 23-DK Compact Heater
Dyna Glo 95-c flame height
check your air passages for a blockage. the wick just aids in burning your fire.
Nov 03, 2007 | Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
