Question about RCA HD52W56 52" Rear Projection HDTV
Not working I have an rca 52 proj. It all of a sudden just quit working. when you turn it on, there's a buzzing coming from the back, but no sound no picture.
Recheck r14705=27k@.5w???according to our prints bob.c.e.t.
Posted on Jul 31, 2007
Hd52w-- check r14705 for an open (should be 12k @ 1/2 watt... res. will probably break as you check it with a meter. if bad change (splitter}!! check Hor. Output for a short (Q 14401 ) it wiLL be bad. i advise replacing high voltage Xformer also (T 14401 ) make sure you cut leads to the proper lengths((not too long))..
Posted on Mar 18, 2007
52 RCA REAR PROJ. TV WONT TURN ON.
The problem will be the deflection board (left hand side board when looking from back of unit.Part number is 258762 is no longer avaible thru rca but you can contact tristate module or pts electronics-you can even google the part number
Sep 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV quit working
is it back projected if so lamp needs changing if not power supply faulty
Dec 08, 2008 | RCA HD52W58 52" TV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH74 rear proj 52inch...gets dark and then fades to black
Yes ,your set like so many others is one of RCAs biggest mess i would say if under warranty get to service center fast!!!! other wise you might be one of the lucky ones that only needs power supply broad solder start with Flyback transfomer solder all pins.
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
82 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
