Question about AmcorAire UCHW-H24AF2 Split System Air Conditioner
I get an External Feedback fault E7
I tried to turn on the heat and got a external feedback failure. This is a heat and cool model nini split.
  • dwhitley7 Dec 13, 2008
    I have the same problem, supposedly brand new unit!!!
  • Anonymous Feb 20, 2009
    I have the same problem.
3 Suggested Answers
  • 400 Answers
SOURCE: ramsond a/c trouble code E7
Indoor/outdoor communication, you can check the connecting cable may have damage.
Posted on Mar 20, 2009
SOURCE: I have an 18 K unit with E7 error on heat mode
I just installed a YMGI brand mini-split AC and had exactly the same problem. AC worked fine, but when I tried using heat mode I would get an E7 error.
After talking to their tech support I discovered the problem. There was a separate cable that needed to be connected that I'd forgotten to hook up. This cable runs from the internal unit to the outdoor unit and connects a defrost sensor.
In my case I had totally missed that cable when I installed the unit. After running another line and connecting it the unit is now functioning normally.
If this is a new install, then make sure all your cables have been run. If it was previously working, then check to see if one of the cables had become disconnected. If it's not the cable, then it's probably the sensor.
Good luck
Posted on Oct 31, 2009
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
What is the split pump
A split system has the parts split up between indoors and outdoors. A heat pump heats and cools your living space with the same unit. A split heat pump has the system split between indoors and outdoors and heats or cools your living space. a SPLIT PUMP sounds like something that has broken.
Feb 01, 2015 | Heating & Cooling
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Mitsubishi 3.5 split systme fault
green light flashing means there was a fault that occurred now it could be power failure which you can try to reset by turning off and on circuit breaker it might reset itself if not there is much bigger problem which need technician
May 10, 2009 | Heating & Cooling
Split Unit not heating
There is no problem the unit is cooling on ly and is not a heat pump so it can't heat.
Dec 27, 2008 | LG LS-K1830CL Cool Mini Split Air...
Ramsond a/c trouble code E7
Dec 17, 2008 | GE Quiet-Aire Ductless Split System Air...
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
AmcorAire  UCHW-H24AF2 Split System Air Conditioner Logo
390 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
