Question about Sewing Machines
Needle breaking b/c it hits needle plate
I can sew ( I can tell that the needle is very close to hitting the plate though) but when I push the reverse button to finish off the needle shifts along with the feed dogs and comes down ******* the needle plate.
    Problem Solver:
  • 9 Answers
Is the needle pushed all the way up into the shaft? It may have worked loose and slipped down a bit.
Posted on Nov 26, 2008
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
Please help I have a singer 140 imperial anniversary edition model 7050 sewing machine, I cannot figure out how to wind the bobbin desperate!! Thank you!
Well, the good news is you can download your user's manual free if you go to the Singer Sewing Machine site. Just select Support, and there is an Instruction Manual option. Enter the model number, 7050, and it is pictured and explained there, beginning on page 15.
You have a Touch 'n Sew slant needle machine, which means you can buy additional feet, as long as they are slant needle ones, and they're very widely available.
Another good feature is those machine wind the bobbin right in place. I have had several of these machines for many years, and frankly, it's my favorite, most trouble-free method.
Bobbins are also widely available; however, your bobbin is available with or without a center button. Yours HAS the center button.
Feb 19, 2015 | Singer Sewing Machines
Reverse button broken
the reverse button that makes the machine sew in reverse is not the feed dog, the feed dog is in the needle plate area. under the needle
when the reverse button is broken the machine must be taken apart and another put in it's place, at a sewing machine repair shop.
Mar 04, 2014 | Euro-Pro Sewing Machines
The right needle on my babylock keep breaking
Perhaps the needle is not fully pushed in or not tight in the holder or has the needle plate moved and the needle is now hitting it? A bent needle will break as it hits the plate but apart from that I cannot imagine what is causing this.
May 04, 2012 | Baby Lock Sewing Machines
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
The needle is entering the machine far to the left. The needle is in correctly and the bobbin plate has not shifted. It appears that the device holding the needle from above has shifted (it shifts easily...
Is your needle position selector stuck? Try moving the dial back and forth a few times. Have your oiled your machine lately? You manual is available on Singerco.com and is free to download. Good luck
Oct 05, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
The needle hits the bottom of the plate, instead of going to the hole in the plate. So, it seems that the plate was shifted a little. how can i get the plate to shift back to its normal position or to get...
Actually, first make sure you have the needle in properly... take it out, then replace it taking special care to hold it straight up and down. If that doesn't work, then the screws on your plate may be loose or one is missing, so manually shift the plate back to where it needs to be and tighten screws.
Dec 17, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
280 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
