Daewoo DVG-9200N DVD Player
Problem for Daewoo DVG-9200N DVD Player
Connections
By Kathie on Nov 28, 2006
I have a simple TV it does not have a TV/VIDEO button to push,I have to use a RF modulator to hook up my other dvd player This TV only has a singel connection for a cable hookup(no audio/video connections) so I use the RF modulator for the dvdplayer I have now (I use the S-video and the red and white audio now), I disconnected the other dvd player and hooked up the new one with the cables supplyed with the player and get nothing I dont have a TV/VIDEO button to push as the instrutions say to do.How do I hook this up using a RF modulator and no TV/VIDEO button to push?
Solution #1
posted on Nov 30, 2006
Somewhat Helpful)
fairlane
Rank: Guru
Rating: 88%, 416 votes
Hi
If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine.
I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables.
If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch.
Good Luck!...These things can be a pain, I hope this helps!
Was this helpful?
Yes
No
Popular Solutions for Daewoo DVG-9200N DVD Player
Questions and Unsolved Problems for Daewoo DVG-9200N DVD Player
Do you recommend Daewoo DVG-9200N DVD Player?
Answer
Answer
it says loading for about 2 minutes then says no disc and makes a lot of clicking noises. what could... (More)
Answer
Daughter's DVD player no longer works. She blames this on pulling plug out of multisocket each... (More)
Answer
Dear Sir/Madam, My DVD player has the red power light on, but no other light is coming on. I... (More)
Answer
F/ware Version : FD3270---PT_2_7_9, (FD3270---PT_2_7_9_DF-L71D1D-BA(20) does not work.
Answer
Hi, I have a Daewoo dvd player, 9200N, which will only display "loading", and never plays... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Daewoo DVG-9200N DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
