Question about Bush 2871NTX 28" TV
Bush LCD32TV022HD LCD TV has lost power and gone blank.
Hope someone can help?
My Bush TV is just over a year old and has basically turned off whilst in the middle of watching it. I assumed the usual things....fuse.....trip switch...etc but when checked these were not the problem.
The first time it happened I changed the fuse and the TV came back on but when I tested the old fuse I found that it hadn't blown.
The second time it happened I did the say again but the TV has not come back on again. There is no red standby light on as if the TV has no power.
I don't have much technical knowledge so if anyone knows what the problem is and can describe what I need to do please keep it basic.
Thanks in advance for any help you can offer.
  • potterjamie Dec 25, 2008
    i have got the same problem but on a 26" tv in my bedroom
    is itworth fixing or`should i just replace the telly
  • nickbid Jan 31, 2009
    i have a bush 32" lcd, hd tv
    the picture has gone but still have sound, when i turn of and then back on the picture is there for a few secounds then goes off,
    any idea whats up??
3 Suggested Answers
  • 19396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 326 Answers
SOURCE: Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Posted on Jun 17, 2007
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Bush IDLCD26TV16HD Left side of screen red causing distortion
Check its degaussing posistor at the power supply regulator section.
Apr 02, 2012 | Bush Televison & Video
My bush lcd32tv022hd will not turn on! No power! Any theories??
First check fuse in pwer board, if it is not burnt then check the main capacitor must pop up, replace the poped component and your tv works fine again. Thanks
Feb 25, 2012 | Televison & Video
My tv has lost picture but still has sound
The 24vdc power supply section may have gone out or the back light inverter board has gone out.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Jul 02, 2010 | Televison & Video
Bush lcd 24 inch tv
Oct 24, 2008 | Bush 5693D 24" TV
Bush 32" TV. desperate situation. T-T
The TV is in protection mode. An internal problem was detected and the set shutdown to prevent further damage. If the set is only 9 months old, it should still be under warranty. Call and request warranty service.
Sep 30, 2008 | Bush 5693D 24" TV
Televison & Video Logo
352 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
