Question about JVC LT-37X688 37 in. LCD HDTV
No video input -- all ports -- for JVC LT-37X688
Problem started with the HDMI ports (both input 1 & 2) where I'd get the "no program or weak signal message" -- but component seemed to work. Tried playing a DVD, and suddenly picture stopped and was replace by white vertical lines spreading across the screen.
Tried the standard reset for the TV and got component input to work, and shut off the TV, went to turn the TV on a couple of hours later and again nothing. Reset process doesn't seem to work now either and access to menus.
TV is 1 year and 15 days old. Any help before I spend money on a new TV or a costly repair would be appreciated.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Posted on May 06, 2009
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
JVC lt-42e478 HDMI No Program or Weak Signal, AV works {blurry and oversize}
Nope sorry this does sound like your control board is naffed and needs replacing , it sees the avi as no rf input is needed but will not switch to if to give you vision chroma and sound .
Jul 02, 2015 | JVC LT-42E478 42 in. LCD Television
Lg flat panel hdmi stopped working shows "no connection"
Check the cable. If the TV has more than one HDMI input, try another one.
Sep 09, 2013 | JVC LT-37X688 37 in. LCD HDTV
View input from hdmi-2 JVC LT-32E478
Port 2 must be a dummy, then!
Aug 29, 2012 | JVC LT-32E478 TV
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
The picture of our jvc LT-46FN97 will suddenly distort
Sounds to me like the digital pixeling that occurs with a weak signal. You have not identified whether this happens on broadcast/antenna TV, cable or satellite service, or a video input such as a DVD. This can be a common problem if you have a weak signal on any of those inputs. In any case, blowing out the dust will not help.
Dec 15, 2017 | JVC LT-42X688 46 in. LCD HDTV
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
Can't connect XBOX 360 please help!
How many video ports does it have? You may have to search through video 1, 2, 3, or switch the TV itself to component/HDMI depending, with the remote. Should be with an 'input' button.
My tv has a list with HDMI, SVIDEO, COMPONENT, PC, ect. and its a 1080p one, im just assuming all HDTV's have a list
Feb 05, 2009 | JVC LT-47X788 47 in. LCD HDTV
JVC LT-37X688 37 in. LCD HDTV Logo
1,107 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
