Question about Carrier 38CKC036 Air Conditioner
Gas pack will not start
Red light on corner of circuit board flashes 6 times and unit makes no effort to start
  • 30 Answers
Check the code reading on the wiring diagram or the door and see what it says. Control boards usually have multiple trouble codes they can blink. Is your Inducer motor running? Any noises at all? Turn the breaker or dissconnect off and reset its sequence. see if you can get it to do anything. If you have a volt meter see if you have 24 volts coming out of your transformer. Make sure you have 24 volts on your W and C terminal on the control board to verifiy your t-stat is telling the unit to come on
Posted on Nov 24, 2008
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
My Panasonic Plasma 42 in will not give a picture now bottom left red light flashes 6 7 times someone has told me that its a resitor that needs replaced but where they said it was i cant find even with the...
USALLY FLASH 7 IS SC BOARD ON SC BOARD THERE ARE MANY MOSSFETTE TRANSISTERS THAT ARE SHORT CHECK TO SEE IF YOU HAVE SHORT TRANSISTER IS YES REPLACE SC BOARD 150 DOLLARS DONT FORGET TO MAKE FIRMWARE UPDATE OR PROBLEME WILL COME BACK !!!!!!!tombou300619_5.jpgtombou300619_6.jpgFIST PICTURE TRANS SECOND C BOARD
Jan 14, 2011 | Panasonic TH-42PZ77U TV
Power light flashes red 6 times. No picture.
The common fault often points the problem being to the power supply or the main printed circuit board.
If you are tech-savvy, you can open the back of the unit and measure, using a multimeter, the voltages from the power supply printed circuit board as well as the main printed circuit board, if the power supply is sending insufficient voltages, its common that you will get the flashing red lights.
Also check for any blown capacitors on the power supply as well as any shorted resistors. I hope this helps.
Aug 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Me too
1.Not an expert with natural gas furnaces.
2.Statements below are from my own personal experience, and knowledge from.
The red blinking light you see is on a computer control board. The flashes of the red light represent a type of code. Think of it as a Morse Code, if you will.
For example: Red light blinks three times rapidly, pause, then blinks one more time. This code represents a particular fault. (Fault = Problem)
There is a sticker, with a chart of codes listed for this red light. It is usually placed very near the red light.
A gas furnace should be repaired by a competent HVAC technician. This is not a device that should be attended to, by those who are not trained.
An HVAC technician will know where to look, what parts are needed, and if the gas furnace is safe enough to put back on line. (Safe enough to use)
Sep 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Carrier 38CKC036 Air Conditioner Logo
285 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
