Question about Edirol R-09 Digital Voice Recorder
R-09 broken, don't know where I can repair one fast in UK
I use a field recorder Edirol R-09 for nature, wildlife and music.
The recorder fell onto some tiles and some buttons fell off.
I need it urgently. When I enquired I was told by Edirol to send it Los Angeles and that the process would take a mighty four weeks.
I cannot afford the time. ...and I don't have the money to buy a replacement.
Any suggestions would be most welcome.
Thank you,
Igor
Hi Igor,
You have probably long since either had your Edirol repaired or found a replacement. If the latter situation is the case, and you have your R-09 sitting around collecting dust, I might be able to help. The buttons likely did not fall off, but were pushed back into the unit. Try opening it up by unscrewing it from the bottom (First open the battery cap) and carefully opening it up. You'll lkely find the buttons pushed back into it.
I learned this after a friend dropped mine at my wedding. Determined, I set out to fix it.
Good luck to you or anyone else reading this post,
Peter II
Posted on Jul 12, 2010
I know this is old, but..I just solved a "freeze" problem with mine. It was booting up, but none of the buttons seemed to do anything at all. Inserting the SD directly into my macbook pro SDSX slot.... if you don't have this, any USB SD reader will do, I erased all the data (and partitions) from the SD card. Using Disk Utility (again, Apple) and making sure it has the MS-dos compatible format. When I re-inserted into my Edirol device, I re-formatted the SD card, and all works perfectly now.This problem occurs if you don't format the card often enough, and then if you can't do it from the machine, try this solution. I think the data struggles to overwrite properly after a while and gets stuck, so format regularly folks!Hope this helps someone out there!N
Posted on Dec 03, 2011
My Ediro R-09 no longer connects to my computer.
maybe the software is corrupted in your computer for the endiro. try to download or the usb cable could also be the problem.
is the memory card removable like in other devices if yes then you can use memory card reader to download.
Aug 29, 2012 | Edirol R-09 Digital Voice Recorder
I have a hotpoint freezer FZS175, the alarm is going off. I've followed the instructions, turned the thermostat to zero, waited, then back to mid-way, pressed the fast freezer button. The freezer
Just had exact same issue with our FZS175 upright Hotpoint freezer - could not reset the alarming state.
Tried defrosting (even though it didn't look like it needed it) but still no change.
Then found the shaft of the little plastic thermostat control knob had sheared off. The only way to tell this has happened is to remove the control panel cover (switch off at mains first of course).
Superglued the broken knob shaft back together, inserting a 1mm steel reinforcing pin (cut from a woodworking panel pin) to prevent it happening again, and all is now well.
I think I am in the wrong profession (British wildlife documentaries)!
British Nature Films Wildlife films of the British countryside
Mar 15, 2012 | Refrigerators
It freezes on the opening page - the one that says R-09HR WAV/MP3 Recorder VER 1.05 it doesn't move onto the normal home screen and it won't let me upload anything from the memory disc. The...
hi,there are two thing that causes this problem the hardware and the software application system.If the application is corrupted the system will not open and gets freeze.Hardware problem will also causes the system to freeze during power on.To get this error resolve I would suggest to bring your recorder to the service center.. good luck and thank you for consulting fixya..
Apr 07, 2011 | Edirol R-09 Digital Voice Recorder
How do i put sound in my computer. pls advise me on this.
Do you want to copy music onto your system or want to record some sound into your system ? Also provide your system details
Feb 01, 2009 | Edirol UA-4FX External Sound System
My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Jun 10, 2008 | Edirol UA-25 External Sound System
Formatting SD card
I had this problem too. Some SD cards won't properly format. My trick was I formatted the card in a different device first (canon Powershot A-630) then put the card in the R-09 and formatted it again. it took about 8 seconds for a 2 gig SD card to format.
Mar 05, 2008 | Edirol R-09 Digital Voice Recorder
Edirol UA-25
A computer has line out and that means sound out from the computer to your speakers. A line out can also be connected to a recording device or a pair of speakers with an amp built in. Line in on a computer can be used to record audio from other equipment such as a Dj on his decks to record his set. It can also record audio from mp3 players etc. Line in can be used for mic's and also you can use mic in as well. To record any audio onto your computer use line in. Line out can also used for headphones and the mic will plug into mic in so you can talk online.
Oct 27, 2006 | Edirol Roland UA-25 External Sound System
Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Aug 29, 2006 | Edirol UA-4FX External Sound System
Edirol R-09 Digital Voice Recorder Logo
376 people viewed this question
Top Edirol Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Edirol Audio Player and Recorder Expert? Answer questions, earn points and help others
