Question about Sony DAV-FX900W System
Problem with rear speakers
Recently we had to send in the dvd player of this system due to a problem with it that caused the sound to not be heard at all. Before we had this problem, we could watch television, play dvds, etc. and be able to hear out of the rear speakers fine. But when we finally got the dvd player back and went to set it up, the calibration setup went fine and all speakers are working but now when I go to watch t.v. I cannot hear anything from the rear speakers, and only do when watching a dvd with a ton of explosions. I called the company I bought this system from but they tell me that is expected because the sound mainly comes from the front speakers. I disagree because like I said it worked fine before hand and now it's not. So, is there anything I can do to be able to hear from the rear speakers when watching t.v. and listening to music or are they useless and spent $800 to use them 10% of the time. Thanks!!
Nightdiver
  • 116 Answers
SOURCE: DVDs won't play
Hi Pookie, This is an easy fix. All you need to get is a CD/DVD-Player Laser-Lens Cleaner for about $5.00. You can get these at Best Buy, Circuit City, Radio Shack, or any similar place. Use this, and let me know how it works for you. Best regards, nightdiver
Posted on May 27, 2006
Arpi
  • 326 Answers
SOURCE: my speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Posted on Apr 12, 2007
spqr163
  • 37 Answers
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Posted on Mar 13, 2009
SOURCE: Sony BDV 370 home cinema system and Sony 40hx703
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Posted on Sep 12, 2010
  • 4 Answers
SOURCE: I recently purchased the DAV-DZ810
Please check the connections TV - o/p and DZ810 - I/P ports..!!
Posted on Jan 24, 2011
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
I just hooked up my Sony DVD Player DVP-SP200P and when I put a DVD in, there is a loud humming sound heard. What could cause this?
It could be here the motor inside that loads/unloads the disc. If unit is opened try to localize where the sound is coming from--is it from the motor or the mechanism?
Replacement DVD players are real cheap now so maybe.........
Apr 04, 2012 | Sony DVP-SR200P DVD Player
Can I set up the dvd player to be listened to without the headphones?
I don't know what type you have...However, Audiovox makes a wired FM modulator that plugs into the back of the radio (wired from the DVD player) that permits the DVD player sound to be heard through the vehicle's sound system. Relatively inexpensive and simple to install. I hope I've helped. If so, please rate my assistance and leave a comment to help others. Thanks and good luck.
Dec 06, 2010 | Car Audio & Video
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Sound issues?
Yeah, your remote has a volume control under the audio button, turn it up.  --Bob---
Aug 05, 2008 | Philips DVP3960
Sony DAV-FX900W System Logo
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
