Question about JVC GR-D350 Mini DV Digital Camcorder
My vista (laptpo) is not working with my jvc dig.cam
I cant upload my videos from my cam to the pc,,,usb is connected and every thing is ok but pc is not recogizing the cam. why
Thanks.
  • anwar1809 Nov 18, 2008
    sorry but whats that softwear wich i need?
  • Anonymous Feb 04, 2009
    I'm unable to download my JVC Gr-D350 Mini DV digitalm video camera movie/pictures to PC using Vistra
  • 31 Answers
Hi there is a software that is needed to be install so that your pc will recognize your camera. Please install it. Thanks Please rate. If you already have install the software.... when you install it do you restart your laptop?
Posted on Nov 16, 2008
  • Hi there if you buy the camera it must have a software to be installed in the pc. If you dont have the software you can browse through it then download it. just type the model of the camera in your browser and click to the nearest result.....
I have a JVC Digital video camera model GR-DV500U I'm trying to connect to my computer with a dv cable. my computer handles the 6 pin but the 4 pin for the camcorder is to large for the connection. Can't...
I presume that you are using desk top computer, thus it has bigger connector. Solution, have find this connector so that one end fit to your cam and the other end fits to your PC. This connector have the same format(protocol) and easy to find in computer store. USB streaming is ok for this model for earlier windows OS, haven't try with windows 7 yet. hope it helps
Feb 26, 2010 | JVC Cybercam GR-DV500US Mini DV Digital...
JVC gr-d70 connection / uploading
open up device manager, right click on your computer icon and select manage, on the management window on the left side select device manager.
find your camera from the device list, note if it has a yellow ! mark or similiar. if a ! is present double click on the camera to get to see the device status info.
Jul 08, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
Uploading to PC
To transfer your video to your pc please do the following:
1. Make sure that you have installed the software that came with your camera. If not insert the supplied cd in your dvd drive. When the dialog box appears select Easy Installation and follow the instructions.
2. Close your camera's LCD monitor.
3. Connect the usb connector to the camera and the pc.
4. Open the LCD monitor and from the menu select Backup.
5. Click all volume and click Next and then Start.
Jan 28, 2010 | Video Cameras
I have Windows Vista and no driver for my camera (JVC GR DX77U)
Hello, have you checked their website for drivers? also which connection do you use between cam and pc ? you should have a firewire connection because usb do sent work.
Oct 28, 2009 | Video Cameras
I have JVC digital video camera GR-DX37AS i have trouble in recording my files from camera to CD via USB mode . the error message shown is USB connection failure
If Your system is OK with all drivers installed, and before the trouble You have recorded to CD any video from Your camera, try to connect the cam with another USB cable. Then try to connect the cam to another usb port, or better to another PC. If the problem persist, the USB of the cam is damaged and must to be repaired in service center. Best regards.
Sep 13, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Vp-d31 cant upload my recordings to my pc
Hi, You need to connect the cam and PC using 4 pin firewire cable.
Switch on the cam.
Open Windows Movie Maker and import the video from device.
Jan 02, 2009 | Samsung VP-D31 Mini DV Digital Camcorder
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
May 23, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
JVC PC810 Webcam drivers
driver for JVC PC810 webcam
Apr 01, 2008 | JVC GR-D770 Camcorder
Everio gz-mg130 won't work with vista
It is easier to connect your camcorder through the included "PowerCinema NE for Everio". First (since you're running Vista), you have to download a patch. Here is the address: http://www2.cli.co.jp/products/ne/update_everioM7SD/pcm4e_update.htm
Note: Only after you have installed PowerCinema NE for Everio can you install the patch. After you have installed the patch, just connect your MG130 to your computer through the included USB cable. Then the software should run automatically.
Hope this Helps
Eric
Dec 29, 2007 | JVC Everio GZ-MG130 Camcorder
JVC GR-D350 Mini DV Digital Camcorder Logo
228 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
