Question about Hunter Heating & Cooling
I am trying to program the thermastat to heating. It runs about 1 minutes and turns off!
  • 31 Answers
Make sure you have at least 3 degree difference between your heating and cooling temp set point
Posted on Nov 17, 2008
On a 1995 chevy lunima have heating problem i replaced thermastat heater core and heat controller still no heat controller
when idling does the temp gauge move on the dash and if you give it gas does it move open the rad cap start the engine let it run for 15-20 mins is the prestone pouring out or is it just setting if it boils out 1-airlock,2-headgasket,after it runs and all the air out try to replace the rad cap possible cap leaking causing no pressure and no heat
Jan 27, 2014 | Cars & Trucks
Which hose goes where on my 2000 pontiac sunfire heater core...
are you installing the correct thermostat the right in the head or block
3 thermostats indicate incorrect fitment method
heater hoses run either way as the water is pushed through the heater core by the pump
Apr 21, 2017 | Cars & Trucks
1992 subaru legacy 2.2 liter overheating and no heat. already replaced waterpump,thermastat, radiator and hoses
You mean the car is running fine but just No Heat?
If so
-Sound like the heater hoses are plug. or the control valve is no function
-Check the heater control valve and flush the heater unit with water of garden hose from both directions.
Q: How do I know that is working or not?
A: Slide the heater control from Hot to cold or cold to hot and check it turn or not. (If not turn at all. The cable is broken or slip off)
Mai Lor
Feb 22, 2013 | Cars & Trucks
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
I have a Goodman ARUF series air handler with a 10KW heat kit. The unit will not stop running and heats all the time. The thermastat is digital and is 3 years old.
your heat-relay aka heat sequencer, time delay... is stuck most likely remove and replace if it checks closed and no 24 volts is going to the timer portion.for 3 to 5 minutes. some of these switches stay closed for 3-5 minutes.after power is removed
Mar 02, 2012 | Heating & Cooling
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Cooling fans would not turn off and i found that the thermastat was bad i disconected battery replaced thermastat filled the radaitor with antifrezze reconected battery started my caravan and now the fans...
when you disconnected the battery, the CPU (computer) modulke got de-programmed. disconnect the negative cable from the battery. Wait a minute then reconnect. you may have to do this several times.The purpose is to reprogram the computer.
Dec 19, 2008 | 1999 Dodge Caravan
Booster heater quits heating water after a few minutes of use and you must hit reset button to get it to work again. What would be causing this? For Hatco C36208 Booster Heater 3 phase
#1 I would check that you actually have 3 phases connected. #2 I would also check the ground. There could be a loose ground, or depending on the installation, the ground could be defeated by rubber washers in flex lines. Fix this by running a wire from the casing of the water heater to the pipe, bypassing the flex lines.
#3 Replace the thermastat. The thermastat has the reset button on it.
#'s 1 & 2 are very minimal in cost. #3 is still affordable.
Please rate this solution
Jul 23, 2008 | Hatco C 24 Compact Electric Booster Water...
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Heating & Cooling Logo
32 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
