Question about RCA HD52W56 52" Rear Projection HDTV
Possible picture tube problem? Delayed picture, blue background, etc.
I bought my HD52W56 last year and all was well until one month before its warranty expiration and the screen started to turn a blue tint when watching a program. At first the screen would switch to the blue tint for a matter of minutes then turn back to normal, but now it is always blue and on screens where there is no picture, you can see lighter blue lines crossing the screen--some curve down/up at one end. Also, when the television is turned on, the screen remains blank only hearing the audio for about 2 minutes before the picture pops on screen. Im leaning towards a bad picture tube, but im no expert. Anyone got an answer to the problem i'd appreciate it. I dont wanna have to spend unnecessary money to have a repair man figure the problem out first then have to pay for him to repair it if its too big of a task for a home-remedy.
  • david96789 Dec 10, 2008
    picture stays red for about one min, shots down
You need go to: http://www.thomsonnetwork.com/NR/rdonlyres/85BBDCA-E5FF-47-EO-8919-FC997DA88... This is the address for RCA>>> (BBN)so you can purchase CHIPPER - CHECK OR YOU CAN JUST GO TO : http://www.thomsonnetwork.com and search from there good luck with your tv p.s.>>>> there is NO lamp in your tv.
Posted on Mar 18, 2007
  • 81 Answers
U should have a lamp in this unit replace it very costly but will need to be replaced and it is better for a repair man to come in and comfirm
Posted on Dec 13, 2006
My rca hdtv does have voice perfectly fine but no picture at all.
Some possible causes:
No filament voltage to the three tubes.
No high voltage to the tubes.
The set is also prone to bad connections at and around the high
Jun 11, 2012 | RCA HD52W56 52" Rear Projection HDTV
The picture on my Sony kp57hw40 has bluish hue to it. It is more visible when what you are watching is darker in color or lower in light. I have tried to adjust everything (color, brightness, etc,etc)...
I have first some information for you and then a possible solution.
A lot of these sets had problems with the 3 picture tubes---blue seems to be the most common--if you go to a unused video input and see anything other than Input 1 etc like blue background or even blue curved faint lines do not despair.
There is a fairly easy way to adjust this (not with the remote) I can tell you the procedure and it requires no parts and only moderate skill.
May I assist you here?
SD TECH
Oct 26, 2011 | Sony KP-57HW40 57" Rear Projection...
Sony Trinitron model # KV-27HFR- the picture is fading, is there a way i can fix that?
From your descrition the problem is the picture tube, over a period of time the guns build up crud reducing the emission on the front screen which in turn causes fading and progressively gets worse until viewing becomes impossible. One possible solution is to have the picture tube rejuvinated by a tv tech to buy more time out of the set, but the improvement may last a few days to several months or more.
Sep 18, 2011 | Sony Televison & Video
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 Too Dark :(
you may need the tubes cleaned and setup
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Dark Picture
...the answer is correct...the power inverter for the cathode backlight is a complete failure with these Polaroid models.  Polaroid should really step up and fix a known problem.  Mine was purchased as a gift and not opened until the worthless 3 month warranty expired.  Didn't work out of the box!!!! I will never purchase a Polaroid product again since they obviously don't care about the consumer and sell a product that they know was defective.
Nov 01, 2006 | Polaroid FDM0700A Under the Counter 7 LCD...
Green is not being displayed on my TV
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Sep 08, 2006 | Toshiba 32AF41 32" TV
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
