Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
No internet on Wireless home network despite ''excellent'' signal
I'm trying to re-connect my wife's computer to the a home network after ignoring the problem for months. The Dell Dimension 5150 connects to a128bit encrypted home network via a Netgear WG111 v2 wireless USB adapter. I have manually entered the WEP key and used Netgear's Smart Wizard to configure the USB device. The computer reports ''excellent''signal strength. The internet runs fine on other computers, through a Netgear Ruckus wireless hub. I've tried removing installation for an old Dell wireless USB adapter (figuring that that might interfere).
Any ideas would be much appreciated.
    Problem Solver:
  • 6 Answers
Go to a command prompt, one way is to go to start, run, cmd and once at the command prompt, type in ipconfig or winipcfg depending on the os. You will get an address like 192.169.1.43. Check that address against one of the computers addresses that can get to the internet. If the first three octets ( the 192.168.1 part) are the same, then check subnet mask. That will be in the same information that you got when you ran ipconfig. If they are different, type ipconfig /release and then hit enter in the command prompt. Once that is done, type ipconfig /renew. That should fix your problem.
Posted on Nov 16, 2008
    Novelist:
  • 93 Answers
When Windows Wi-Fi utility reports available wi-fi networks, does yours show up? I would imagine so, if you're being prompted for the key, and you entered it. So, you should be connected to the LAN at that point.
Then it is a question of connectivity. Using "My Network Places", see if you can detect the other computers on the Local Area Network. If they don't show up, but all indicators say you are connected, right click on My Computer, then Properties. On the popup box, you will see "computer name", and beneath that, "workgroup". Make sure that computer is in the same workgroup as the rest of the network. If not, the bottom button will allow you to change the name of the workgroup.
If you can see the other computers on your network, but you just can't reach the internet, take a look at whatever firewalls you are running, and make sure that PC isn't being blocked by one of them. An easy way to check is to temporarily turn all of them off, and see if things start working.
Also, if you can access your hub (using the web interface), check there and see if the Dell desktop is showing up as a connected device at the router.
I would almost bet it is a workgroup issue, but if it isn't, let me know. There are several other things we can take a look at.
Cheers
Nick
Computer says,"connected to network signal strength excellent", but I cannot connect to internet
Can you connect to the Internet using the LAN cable?
Have you configured the wireless card in your laptop with the router's wireless settings?
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 20, 2012 | Acer Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
Excellent Wireless signal but limited or no connectivity
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Wireless connection problems with toshiba satellite a105-s4334
You will have to run the home or office wizard on your existing connection to start using internet. You can activate the wizard through the network connection icon in control panel. There inside the network connection window on left side, u can see the link to it. Follow the steps. Ignore disconnected hardware if any. Do rate my reply... Thanx n regards
Jan 05, 2009 | Computers & Internet
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
126 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
