Problem wiring new thermostat - Heating & Cooling
  • 76 Answers
9 TIMES OUT OF 10 YOU PLACE THE COLORS ON THE TERMINALS MARKED W/ THE WIRE COLORS. BUT YOU SHOULD LABEL THE WIRES TO THE CORRESPONDING LETTERS ON THE OLD THERMASTAT THEN PLACE ON SAME LETTERS ON THE NEW. HOPE THIS HELPS EX. YELLOW (Y) RED (R)
Posted on Nov 16, 2008
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
Thermostat wire problem
That's very possible. Maybe when you were pulling it was snagging on something. I would strip the new wire again at the splice and give it another shot. Possibly
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 09, 2017 | Honeywell Programmable Thermostat Heater
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
I am replacing old 220 volt thermostat with a programable 220 volt thermostat. There are 6 wires in the box. (3 black & 3 red) There are only two black wires on the new thermostat. On the old...
Hi, this can be confusing. Be sure you have the power off before you wire it, but first you have to have an elect meter. The 6 wires in the box you will only use 2 of them. Cap the other 4 off. Use the 2 that have the correct voltage across them, 208, 220, 240 volts. The new stat is only set up for 2 hot wires 120 each. That will do it. Not to bad. be careful! Use care. Good Luck, Sincerely,
Shastalaker7
Nov 08, 2009 | Heating & Cooling
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring in a new thermostat
yes .common as in the netural side of the transformer x to cif not hooked up the stat will still work. and honeywell has good support for their products . Tom
Jun 20, 2009 | Intertherm P3RA-048K Air Conditioner
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
215 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
