HOW DO YOU CHANGE THE FUEL FILTER ,DO YOU HAV TO USE A SPECIAL TOOL ITS FOR MAZDA BONGO
Go to link. fuel filter
SOURCE: hi in need of a wiring diagram fuse box Mazda bongo
look here: http://www.bongoforum.co.uk/forum/Blah.pl?
SOURCE: fuel starvation mazda bongo
Bongo 2.5 Tdi. WL-T.
Everything fine untill 20 minutes after fueling up the engine started to run rough when stopped(at idle). I shut down. Couldn't restart. Next morning started up and ran fine. later on, wouldn't start easily and when it did couldn't rev above 800rpm. another time started but no power.
Seems like fuel starvation. I just bought the van and have sent away for workbook, fuel filter, glow plugs etc. Where is the fuel filter located? I see where the fuel line goes in to the FCU (or flow devider) is this where i should check presssure. I know a little about petrol engines but nothing about TDI. Any help would be greatly appreciated!
Thanks,
Rowan
SOURCE: how to change fuel filter 2000 excursion
Yes it is the tool for fuel lines and ac lines. Your local autoparts store should have them, they are universal. You need to use the small end for the fuel filter.
SOURCE: Changing fuel filter on 2004 Cadillac SRX
If you go to the auto parts store they should have a fuel line disconnect tool that has a 5/16ths end an a 3/8ths end. The tool is shaped like an X. Before you start you need to pull the fuel pump fuse under the front of the REAR passenger side seat while the car is running and let it stall. it will release the built up pressure. This is important unless you want gas to spray every where. Then take the tool and start with the end of the filter with two lines. Place the appropriate end of the tool over the smallest inlet, push the tool in then pull the line towards the filter and then push the line away and it should disconnect. Do the same with line above. Then you can use the two appropriate size wrenches to disconnect the outlet end. reconnecting the new filter is simple just make sure your quick connect lines click in all the way and you tighten the outlet line well, I think its like 22 or 25 ft/lbs.
SOURCE: How to Replace a Fuel pump on a 2000 Mazda 626
yes it isn't that much if you buy them.they slide inside the coupler and release the line.
Testimonial: "Thank you didn't know if there was a tool for this."
