Question about Haier XQB40-F Top Load Washer
The water runs right out the machine with the hose on tight.
The water runs right out the tub of the washing machine on the floor with the hose on tight .
Hi. I need to bay hose on tight,but i don't know in which store in Brooklyn,NY.Thank You.
Posted on Dec 18, 2008
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
Oct 02, 2010 | Maytag Washing Machines
My washing machine will not fill up with water. The water is running into the machine but never fills the machine. It seems like it is just running directly out again. I own a frigidaire top loading...
The drain hose must be higher than the tub. Had the drain hose at any point been lowered or dropped in such a way that it would be below the tub?
Dec 22, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Water runs out onto the floor
the drain hose is off the pipe or other hoses from the pump to the wash tub. old hoses have a split in it. could be more than just hoses.
not easy but fixable you will need to unplug the unit and take the back off and have a look see. good luck and have fun.
Dec 21, 2008 | Kenmore 22422 Top Load Washer
Water runs, but tub does not fill on whirlpool washer
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
Sep 14, 2008 | Washing Machines
Lint build-up on clothing after coming out of washing Machine
ck to be sure drain hose is not more than 6-8 inches into standpipe ..standpipe is 30-36 inches to top from floor ..drain hose does not fit too tight in standpipe any of the above conditions may cause water to siphon out during wash or rinse resulting in not enough water in tub to carry lint away during drain
Sep 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag performa washer
check to see if the tub to pump hose has pulled off
Dec 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Haier XQB40-F Top Load Washer Logo
164 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
