Question about RCA P52960 52" Rear Projection Television
NOT TURNING ON
The tv will not turn on it makes a clicking noise like it wants to come on. i have had this problem 5 times and it has been told to me that it is a problem with the power supply . can any one help me?????
  • loven her Mar 23, 2008
    My panasonic HDTV is not turning on all it is doing is flashing red light and then stopping how can i fix it?
  • 81 Answers
It is a power supply problem. disconnect the horz. output collector plug it in and hear if you have sound. if the same check for 13v 24v if U are not a tech do not try to do this.
Posted on Dec 15, 2006
SOURCE:
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
My tv clicks like it's turning on but the blue light doesn't flash and it just wont turn on, it still makes the clicking noise though. 56 inch I think.
My Hitachi 57S715 did the same thing recently. I've been told that it is probably a problem with the power supply. Did you ever get a definitive answer to the problem?
Aug 09, 2010 | Hitachi 57S715 57" Rear Projection HDTV
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
Dryer makes a scrubbing noise then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
djdgh
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
Clicking noises before TV turns on.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
Nov 07, 2009 | Samsung LN-S4052D Television
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
RED LIGHT IS ON BUT IT WILL ON TURN ON(GREEN)
Feb 18, 2009 | Akai LCT2715 27 in. LCD Television
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
