Question about Frigidaire Washing Machines
Frigidaire front load tumble action washer won't run
Error code LOC
model number LTF2940E50
serial number XC50713540
I have unplugged it, pressed start & cancel simultaneously
seems the control board is locked because you can't change any of the settings through the buttons. Can only turn the knob to change the type of wash.
  • dierickx_55 Nov 16, 2008
    It worked! Thank you very much
    Scholar:
  • 181 Answers
What error do you get exactly on the display.
Posted on Nov 16, 2008
  • 2 more comments
  • fixyy Nov 16, 2008
    it should be starting something with E.
    http://www.applianceaid.com/frigidaire_f...
    check out this link to all the error codes and their resolving method.with proper steps 1 by 1.
    To recall an error code:
    � Wake the machine by pressing any button
    � Wait 5 seconds
    � Press and hold the Start and Pause Cancel buttons simultaneously
    � All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed. A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
    Diagnostic Test:
    The diagnostic test is performed by using the Program Knob. To START THE TEST:
    � On non-digital display models, turn the Program Knob to start position, Drain/Spin.
    � On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360�, turn the Program Knob to start position, Drain/Spin.
    � Press Pause Cancel to turn off LEDs.
    � Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
    1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality.
    2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment.
    3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment.
    4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment.
    5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
    6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
    7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
    8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
    9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
    10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
    Sergeant:
    Champion:
  • 200 Answers
HI
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
thank you
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do i reset/delete all the data codes for a frigidaire galley model GLTF2940s53
Disconnect power to reset the control to return washer to normal
operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
• Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation
Jul 17, 2014 | Frigidaire GLTF2940ES Front Load Washer
Im having a problem with my washer it won't work and its flashing loc
Good Afternoon Jesslyn, I am happy to assist you!
I understand your washer is not working and flashing LOC; however, I see that your question is listed under Frigidaire FEX831CS (Top Load Stacked Washer/Dryer). This specific laundry center does not have a digital display. May I please have your model number? You can typically locate the serial tag, on the upper front as you open the door.
In the meantime, if you have a front load washer, I suggest pressing OPTIONS and SELECT at the same time and hold for approximately 15 seconds until "LOC" is no longer displayed. I hope this helps!
Thank you - Z.
Apr 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error code "loc" on GLTF2940ES0 washer
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
