Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon pixma mp110 saying ''please load paper and press ok''
When printing, my MP110claims "Please load paper and press OK". Sincethere is paper, I press OK and the paper continues half through andagains asks me to load paper and press OK. I press OK, and the paper isled the rest of the way through the printer (however, the printerdoesn't print).
please help!
  • Canon Master
  • 19,396 Answers
The paper feeder and the tractors work, since the paper is being loaded, just do not guess when you do not know something.
Posted on Nov 18, 2008
    Scholar:
  • 181 Answers
There is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Posted on Nov 17, 2008
Attention red light on near the c button. fail to print until press ok or c twice every time to do the printing
Check the paper size and paper type settings, this error usually triggers if your application asks for a certain size or type of paper but that paper is not loaded in the printer. Pressing OK tells the printer just to print on the paper you have loaded.
Mar 15, 2015 | HP LaserJet P4015N Printer
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Every time when printing there is a message MANUAL FEED, load paper and click continue
Please check your printer driver to see if the default tray is tray 2 or other than the manual feed tray and take the paper out of the manual tray.
May 03, 2011 | HP LaserJet 3200 All-In-One Printer
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
Printer won't print properly.
Please perform the following steps:
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Regards,
Sagarjd
Nov 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
Would not print C5280 Flashing Failure Print Cartridge allignment
Solution
  4. Press the down arrow to select Align Printer and then press OK . The unit prints a test page, aligns the printhead, and calibrates the printer.
Cause An incorrect type of paper is loaded in the input tray. If you have color or photo paper loaded in the input tray when you align the printer, the alignment might fail.
Nov 04, 2008 | HP Office Equipment & Supplies
Canon PIXMA MP130 All-In-One InkJet Printer Logo
708 people viewed this question
old marine
old marine
