Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Faint statc and green lines on screen
The screen is very faint and has some horizonal lines that are green in color. You cannot see any of the functions, such as volume or channel number on the screen as well. You try and push the buttons on the panel below the screen or on the remote and nothing seems to happen. I don't want to spend too much money to fix it, but if it's a simple solution I'll try it. Thanks in advance for any advice.
    Genius:
  • 1,153 Answers
If they are at left side of screen, change r701, c268 move focus wires as far as possible from the red crt
Posted on Aug 16, 2007
I just replaced led strip on samsung un40h5203afxza tv. It works but I am now getting faint horizonal lines over the screen. How do I fix this?
I hate to give you bad news but you damaged the LCD panel when you had it out and its either live with the lines or throw the TV away, its easy to damage the panel when handling them
Apr 25, 2018 | Samsung Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
How do you determine if CRT is shorted?
you should have some perdomnint color showing on the screen EX: red or blue or green a faint line or lines may be present very common on sonys crt s are not avail any more
Nov 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Sep 16, 2007 | Televison & Video
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
42 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
