Question about Roper REX4634KQ Electric Dryer
I have a Roper dryer machine, and it does not heat.
How do I can fix this problem?
  • Anonymous Dec 30, 2008
    Our machine willl turn on and tumble nut no heat.
  • Anonymous Jan 03, 2009
    help
  • 198 Answers
With an ohm meter check continuity of the thermal fuse mounted at the top of the heater box, If that is ok check the heating element
Posted on Jan 18, 2009
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
I have a whirlpool brand is Roper. It has just stop drying, NO HEAT. is it easy to fix myself?
FIRST UNPLUG THE MACHINE, THE GAS VALVE HAS 2 BLACK CYLINDERS CHANGE IT, AND CHECK THE THERMAL FUSE ITS LIKE DOG TOOTH SOME TIMES ITS ON THE BACK.THIS ACTIVE THE IGNITION.
Nov 10, 2010 | Roper Dryers
Roper Electic Dryer EL4030V - comes on - runs good - just no heat?Would like to try to fix myself? Where to find good instructions with pictures?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 21, 2010 | Roper Dryers
I have no heat i checked continunity on the element and replaced both thermostats but still have no heat. i have a roper dryer model number rex6634rq1
Check your electrical breakers
Be sure to check your voltage coming to the dryer at the plug and the machine back where the wires connect to the terminals you should have 220Volts.
I think this may be your problem with no heat.
This is a free answer, Please rate me
Oct 03, 2010 | Roper Dryers
We have brought home two new roper dryers now because neither one of them heats up. we hooked up a brand new 3 prong plug to the new dryers and plugged them into the existing 220 outlet that our old dryer...
You need to double check that your wiring it up correctly at the junction block on the machine. if thats correct. Most likley is that you actually only have 110 volts going to the machine it will run fine but will not HEAT. check voltage at plug or where its wired into back of unit you should have 110 volts on two out of three with the third being ground if you dont you have a bad outlet or breaker in elec.panel
Aug 08, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Roper Dryer will not heat
I don't have a picture of the rear panel available, but if you have to remove the exhaust duct to remove the panel, I would be checking to ensure the exhaust ducting is not clogged/restricted. The duct does not have to be completely blocked to cause the dryer not to heat properly.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating
Everthing is on the back. Unplug the appliance. remove the rear panel. This is a sweet machine. Very easy to fix. The element comes right off easily (2 screws either side of it). Look for breaks. if the element is kosher check the hi-limit mounted on the same heater above on the left. Hey here is some pic:NOTE Not shown is the 300 degree limit mounted at the top!!!38d8abb.jpgc4945e0.jpg
Dec 16, 2008 | Roper RES7646KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
70 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
