Question about Reiker Room Conditioner Ceiling Fan with Heater RRC12001
Reiker ''room conditioner'' heater stopped working
Recently purchased a Reiker room conditioner for our TV room. Worked great for about a month and now the heating element has stopped working. Remote, light and fan are still operable. Any suggestions?
P.S. Purchased new in box from ebay.
  • 3 more comments
  • ronbouk Dec 13, 2008
    Ditto, same problem. Any help?
  • getsy1104 Jan 07, 2009
    We have the exact same problem. Fan is only a year old, so it has only been used for heating for a few months. LIght and fan still work fine, only heating has stopped. Any help is appreciated.
  • nybowbum Jan 14, 2009
    I have the Exact same problem!!! What's going on?
    Did anyone figure out how to fix it yet?????
  • Anonymous Jan 25, 2009
    I have the same problem.
  • tlbad Mar 25, 2009
    I have the same problem, any fixes yet?
  • 3 Answers
I've also had this problem. Solved it with the reset button on the back of the remote. It's under the battery cover, next to the dip switches.
Turn on the remote, with heat. Then, at the wall switch or circuit box turn off power. Wait a few minutes. Restore power and within 30 seconds with remote in range of fan hit the reset button. You should see a countdown from 5-0 on the remote screen.
I did this and the heat started working again.
Posted on Feb 17, 2011
  • 2 more comments
  • JBMBD Feb 25, 2011
    I tried your solution and it got the heater working, but after a minute or so it turned back off. I tried it a few times and still the same issue. Any ideas on what the problem might be? The manufacturer is not very helpful. They told me I had to remove the fan from the ceiling and send it to them at my cost, both ways. Not great customer service for a fan that is less than 6 months old and the heater has not been used that much.Any help is appreciated. Thanks, JD
  • Natasha Wieszt Nov 26, 2012
    Thankyou, Maggie90! After reading your post I was finally able to reset the remote and it is working now.
    Thankyou Maggie90! After reading your post I was finally able to reset the remote. It is working now.
  • chuck bacon Aug 03, 2013
    When the unit is working does it heat the whole room & does it work when the temp. is "0"?
I have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Posted on Nov 03, 2009
After reading the manual I was unable to reset the remote the way it suggested. I tryed many times. After reading Maggie90's post It worked right away. So, thankyou.
Posted on Nov 26, 2012
Ceiling fan blades
Call the manufacture of the fan.
Aug 18, 2014 | Reiker Room Conditioner Ceiling Fan -...
Heating element for reiker room conditioner chalet ancient bronze model
I would look for a bad thermostat on or near the heating element. If your not sure with electrical work, it might be best to replace the whole thing. Most cieling fans cost less to replace than repair.
Dec 13, 2013 | Reiker Room Conditioner Chalet Ancient...
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
My AC 1200BTU work in heating 5min. and than stopped
Check temp setting and also room sensor. Setting must be minimum 3 degree more than room temp. Check continuity for sensor. If open replace it. Check coil , air filter and heater element are cleaned.
If high amps, replace heating element. Thanks.
Feb 07, 2011 | LGLXA1230 Air Conditioner
The room conditioner is noisier now than when I got it. When I looked at it, it seems that it might need cleaning. How do I do that?
I would start out by wiping down them damp sponging the fan blades top and bottom. If you have a air copressor and don't mind a mess you can use low pressure air to blow thru all the cooling ports on the motor.This is the way I clean ours but it doesn't make my wife very happy. You can also shut off power and disassemble to the point you are comfortable with then brush and vacumn.
I have found that the ones that I have taken completely down,while it does make them easier to clean they have all had sealed bearing motors so not able to lube.Hope this helps you. Thanks.
Feb 04, 2011 | Reiker Room Conditioner Ceiling Fan with...
Light flashes, clicking noise, fan does not turn
it sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Feb 05, 2010 | Reiker Room Conditioner Ceiling Fan with...
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
called reiker, and they sent me a new thermostat for the fan. installed it and problem solved
Jan 27, 2009 | Reiker Room Conditioner Ceiling Fan with...
Reiker Room Conditioner Ceiling Fan with Heater RRC12001 Logo
1,573 people viewed this question
Top Reiker Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Reiker Heating and Cooling Expert? Answer questions, earn points and help others
