Question about Nokia 447Za Monitor
Nokia Monitor Multigraph 447Za - Speaker/Microphone Volume control not working
Hi, I have a problem with my monitors volume controls for the built in speakers and the microphone volume. Neither seem to work turning the respective volume down using the soft rubber keys on the front of the monitor ? Is there soem form of OSD or reset facility as the problem is really annoying !? Please provide any useful advice Chris
  • 1 more comment
  • Danielle Marc Dec 31, 2007
  • t2potts1 May 20, 2008
    Speaker and Micpone not working
  • ejfoxylady Sep 21, 2008
    I also was adjusting the monitor buttons and now the sound is not working and when I try to move the volume up and down it gives you that bong sound like when you get two many windows out at one time or went too fast for the computer to catch up, Please advise.
The electrical contact surfaces under the rubber buttons lose contact over time. I don't know if it's corrosion or some kind of build up. I fixed mine by disassembling the monitor, removing the button panel and cleaning the contacts with a pencil eraser. It works great now. The monitor is a real bear to take apart though. There are four hidden spring tabs on the sides of the bezel that are impossible to see. I groped with a very thin screwdriver blade and finally got them to release, but not without chipping some of the plastic.
Posted on Mar 08, 2009
Hi mam / sir the problem of my acer7715z its has n built in microphone and the volume of its speaker is to low how can i fix problem thanks
You can turn up the volume via the speaker icon in the lower right hand corner. If that doesn't get it to the level you'd like, then the speakers there aren't that powerful.
Jun 19, 2011 | Acer AL1713 17" LCD Monitor
My advueu monitor has built in speakers which are not working now. do not know what is wrong
First--have the speakers worked before? If so, be sure the speaker wire is plugged into the green hole on the back of the computer and also plugged into the monitor.
Is there a volume control on the monitor? If so, be sure it's turned up.
Are you speakers muted? Check in the sounds icon in the control panel (there could also be a little picture of a speaker in the system tray. Many times people mute the speakers and forget they did it.
Also in the sounds area of the control panel, be sure the volume is turned up.
Oct 06, 2010 | Computers & Internet
I want to use my Acer TravelMate 5710G for Skype video calling, and the built-in microphone on the top of the screen is not working. How do I switch it on?
Right click on the speaker icon in the system tray and choose Open Volume Control. In the Volume Control window, select Options, select Properties. In the properties window, place a checkmark by Microphone in the Show the following volume control properties section. Click OK. You should now see the control for the microphone. Uncheck the mute box and the microphone is now enabled.
Jan 10, 2010 | Computers & Internet
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Monitor Microphone
make sure you have the mic cable plugged in the right port at the back of your computer. double click on the speaker on your desk tray, lower right corner by the time-date location, the Volume Control window will open. Check if you have the Microphone column, and the Mute check box is not mark. If you can't find the Microphone column in your Volume Control window, click Options > select Properties... check the box that says Microphone... then click OK. Now you should see the Microphone column... uncheck the Mute box. Test your mic now....
May 31, 2008 | HP Pavilion MX70 17" CRT Monitor
How on earth do I control the volume on a Dell E172FPB monitor?!!
What dell model is it. Most did not have speakers built in. There are clips to install an optional speaker bar on most dell monitors. But it has its own bolume control.
May 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor Built in Speaker Problm
Hi shah. It is most likely that the speaker's transformer is burnt. If its under warranty then the showroom guys should fix it for you as its covered under warranty. Otherwise you will need to take it apart remove the old transformer and install a new one. I strongly advise "if you are not familiar with electricals then better take the assistance of a qualified engineer".
Regards,
Eagle338.
Feb 23, 2008 | Nokia 447Za Monitor
Speakers
Start with the obvious! Are all connections to PC connected? Be sure that the proper wires are connected to the proper plug in.
Next you may have to adjust the volume control thru Windows. Look for the small speaker icon at the bottom right (usually) of the screen. Double click, and be sure that all of the volume controls are "up" and be sure that none of them are "muted"
There also may be a volume control on the monitor, speaker assembly.
Dec 31, 2007 | HP vs15 15"LCD Flat Panel Monitor
Aspire 3628ANWXCi built in microphone
Go to your speaker icon in your task bar on right hand side and right click then on volume control. Go to file then select options/properties and then scroll down to the microphone on the show volume controls box and tick it. The microphone volume slider should now show and make sure the mute is unticked.
Jan 17, 2007 | Acer Aspire Notebook PC
Nokia 447Za Monitor Logo
637 people viewed this question
Top Nokia Computers & Internet Experts
k24674
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
