Question about LG WM-1480FHD Front Load Washer
LG WM1480 spinning problem
Hi, My LG WM1480 washing machine is having a problem spinning at or below 1000rpm. Initially it spins fine but when there are 6 mins on the clock it stops spinning and starts refilling with water (through the prewash part of soap dispenser) then empties (but doesn't spin) then refills and empties non stop. The timer sticks on 6 mins. This doesn't happen when a 1400 rpm spin speed is selected - it spins correctly till end of cycle. We have checked the filter and there is nothing blocking it. I'd be grateful for any help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Unfortunately you will need to have the main board replaced on the unit. Something has happened to the software settings on the main board for that particular cycle/spin speed. The only solution at this point is to replace the entire main board. Hope this helps. Please rate my solution.
Posted on Jan 11, 2009
GE WBHV5200J3WW shakes during spin cycle with load in the machine
you might need a new Motor Asm Kit part number WH20X10028
the pic below is Motor Asm Kit that you might need okay
Jan 29, 2013 | Washing Machines
Lg wh2277hw will not spin. takes water and attempts to spin but no.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 14, 2011 | LG WM-2277HW Front Load Washer
My LG washer will not spin
heatman101
Oct 07, 2010 | LG Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Machine works fine up to the spin cycle
heatman101
Aug 31, 2010 | LG Washing Machines
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
1000rpm spin?
machine is programed only to reach 800rpm in that program
try different program to suit your 1000 rpm desired speed
Nov 23, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
LG WM-1480FHD Front Load Washer Logo
357 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
