Question about Maytag EPIC MFW9700S Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
My mom's Maytag front loading washer is on a concrete floor, has been leveled and lock nuts tightened down. It still vibrates so badly during any spin cycle that it walks across the floor.
  • ssbuck Nov 16, 2008
    Thanks - we'll check it out. This is certainly more helpful than the Sears repairman who came out and did nothing!
  • dootdah Dec 14, 2008
    Spin cycle causes extreme vibration (ceramic tile floor). Very noisy and washer moves out of place
    Scholar:
  • 131 Answers
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
WHERE CAN I FIND PEDESTALS FOR MAYTAG NEPTUNE WASHER AND DRYER MODELS MD55 AND MAH-1 MODELS?
Don't...Unless you have a concrete floor you will never be satisfied with the pedestal. Your front loader will shake a lot more. People buy these things then I go to there house with a "shaking" problem and then they get mad at me because I tell them it's because of the pedestal. Front loaders were designed on concrete floors so they're only going to work like they say on concrete floors. Do a little research before you make that decision please. Not to mention they're about 200 dollars or more. Just a heads up I don't mean to bring ya down.
Apr 02, 2011 | Washing Machines
WE recently purchased a front loading Frigidaire washer. I love it except we can't seem to get it level so it doesn't vibrate. It is on a concrete floor and thought the feet were self leveling but that's...
Make sure you have removed all the shipping bolts and straps. Front loaders come with bolts that go thru the back to keep the drum from moving during shipping. If you brought the washer home yourselves you may have left in these shipping bolts. Refer to you installation manual. It will give detailed instructions on how to set up your washer. If bolts are left in place the washer will vibrate and shake excessively and cause major damage if left in for too long.
Feb 03, 2010 | Frigidaire GLTF1670A Front Load Washer
I have a LG WM2032HW Front Load washer that shakes like crazy! It is level, shipping bolts are removed and it does not matter if the washer is empty, just a small amount of clothes or full!
your problem may be in the shocks or because this machine is very powerfull and spins very fast that the floor is giving (has play) and needs to be supported up from underneath it if u put the machine on a cement floor lock the legs securly to the machine if it spins fine then your floor is the problem
if it still shakes then i would replace the shocks
(sol v ya prob)
Oct 17, 2009 | LG WD-1280FHD Front Load Washer
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
MAYTAG WASHING MACHINE FRONT LOADER, VIBRATION
Hi jill_perigo
I have a couple of question, 1. did you remove the block? 2. is the machine on a concret floor? 3 how old is your machine?
brent
Sep 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Maytag front load washing machine
I have the same problem and its making me crazy.
Feb 04, 2008 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
830 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
