Question about Husqvarna Backpack Blower, Model No. 356bt
The pull string won't pull
We used it just the other day and put it away, now it won't work. I can't pull the rope to start it.
  • marrezey Nov 16, 2008
    the pull won't pull.
  • josh1111 May 11, 2010
    sounds like the recoil is jammed. take the pull cord assembly off and tell me what you see
  • 211 Answers
check the piston rings and bearings
Posted on Oct 07, 2009
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
More results from
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from
Jan 04, 2016 | Garden
Went to start my XL500 homelite chainsaw and the rope won't pull out.It worked fine when I ran it dry for storage, now it seems like th sprocket won't turn. looks like chain oil is comming out
If it is bar oil then the gasket is leaking between the oil tank and the crankcase, this would mean a full strip down and replace the gasket.
Feb 10, 2013 | Garden
The pull starter on my Morrison BC260B S2 won't
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Feb 18, 2012 | Garden
I pulled the starter rope out of the unit. How do I take the unit apart to re-wind the starter rope?
Take the cover off and look under it, you should see a plastic round disc that the rope winds on, You will need to locate the string and get it out of the cover where it passes through,once this is done, you will have to turn the disc the correct way to tighten spring ( you should be able to feel the pressure building as you turn, if not go other way, or the spring is broke, in wich case you need parts. If all is well, when you feel tension on it and have enough....not to much...just think about how much pull you had before it broke,because when the rope comes out it gets tighter towards full pull of rope, HOLD tension and put string through the hole on cover, once you have it through tie your handle back on, you should be able to release and jossle to get the rope back in the groove, Place on machine and see if you have enough tension that it will retract in cover when pulled and let go, if it does not you will have to repeat procedure, and tighten spring.....Do not get carried away with the loading of the spring......TIP you can shorten string if you just lack a little bit of it retracting in cover because it gets tighter when pulled out....Good Luck!
Nov 26, 2010 | Husqvarna Craftsman 200 Mph 430 Cfm Gas...
Homelite 25cc model UT20002A. How to repalce starter string?
Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I put in a new pull string
Please check the bellow link…
Unscrew the coil housing for the rope using a socket set or screwdriver. Do not tip the mower over on its side when working on it because this can often cause oil and gas to leak out. Check out the coil wheel. Depending on where the rope broke, you might have some rope left on the coil wheel. You can feed the old rope back through its hole and retie the pull handle if you have enough rope to pull start the mower. Next, replace the housing and then screw it back in place. If you do not have enough rope, you will need to replace it with a new one. You can take a wrench and loosen the bolt that holds this in place. When you pull the wheel off, in most cases it will include the winding spring that coils the rope automatically.
Loosen the bolt that holds the coil pulley in place. When you take off the coil pulley, the coil spring will come off with it in most cases. Cut off the old rope using a knife. To remember which way the rope was coiled, make an arrow with a marker.Pull the new rope through the hole and tie a knot about the same size as the old rope because you do not want the new knot to catch on something when the coil pulley coils and uncoil. Wrap the new rope in the direction of the arrow you drew. Next, bolt the coil pulley back in place. To make sure it is working properly, unplug the spark plug- this allows you to pull on the rope to make sure it coils and uncoils correctly.
Pull the end of the rope through the hole in the housing. Tie the old pull handle to the end of the new rope. If the rope is too long, you might need to cut off the extra length and discard it. Place the house into its spot and screw or bolt it back on. Finally, put the spark plug wire back into place.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting
Jul 09, 2010 | Garden
My lawn mower won't start.
pour a little gas in carb then pull rope see if it starts or starting fluid
Jun 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna Backpack Blower, Model No. 356bt Logo
259 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
