Question about Maytag PYE2300AY Electric Dryer
MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU HELP ME?
MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU TELL ME THE PROBLEM?
  • Anonymous Jan 30, 2009
    where is the switch to the heat element? the drum does turn and the air is blowing better than ever before only the air is cold
  • Anonymous Mar 14, 2014
    ELECTRIC DRYER
  • 623 Answers
Without seeing it, and very little info to go on, let me ask this, does the drum turn?
If there is no heat, go outside and check the exhaust, do you feel air blowing out?
If you do, then the heating element may be bad or the switch that sends power to the element may be bad. If no air blowing out, then I do not know any further. At any rate, a service man must come.
Posted on Nov 16, 2008
No Heat on a Maytag Neptune Electric Dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\][[
Jul 23, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My dryer doesnt heat at all
heatman101
May 15, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag DE 482 Does not heat. How do I tell what the problem is?
heatman101
Apr 29, 2011 | Dryers
Dryer runs but doesnt get hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 23, 2011 | Maytag PYE2300AY Electric Dryer
Igniter works but there doesnt seem to be any gas. can i test the leads to the gas thing for continuity? anyone?
heatman101
Dec 13, 2010 | Maytag Dryers
The heat in my dryer doesnt seem to be working. Any ideas where I should start?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 25, 2010 | Maytag Dryers
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
My magtag dryer mde9520 won't heat. How do I tell
You need a multimeter to test the voltage and continuity
Jun 30, 2009 | Maytag Dryers
Maytag gas dryer will not heat up.
The most common cause for "No Heat" on GAS dryers is bad gas valve coils. Go here for more: Dryer Repair Help
Go here for Maytag Dryer Part Info: http://www.repairclinic.com/Maytag-Dryer-Parts
www.RepairClinic.com
Feb 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
150 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
