Question about Whirlpool Dishwashers
Fixed noisy problem now I have a new one....
We fixed the impeller on the washer and its nice and quiet now and actually starts to run but then kicks off on its own and won't finish. I don't think its spinning freely and was wondering if anyone knew if we missed a step somewhere in the instilation of the new impeller and chopper or if we needed to do something else? HELP, its close to Christmas and I have 20 people comming for dinner. I NEED my dishwasher.... Thanks...
    Top Expert:
  • Whirlpool Master
  • 28,711 Answers
"its close to Christmas" It is July!
Check the wash arms run free.
Posted on Jul 12, 2017
SOURCE: Noise
I have a PAV2300 and I recently experienced a grinding noise. Turned out to be the pump pully has a sleve between the pully and the bearing that has slid out of position. I took the pump out and using a small bladed screwdriver, wedged it between the selve and the base of the pump and working my way around it several times, managed to press it back into place. On the PAV2300 the pump is in the back of the unit. Looking at the picture the sleve is between that pully and the black base. Hope this helps. Good luck :)
Posted on Feb 28, 2007
emissionwiz
  • 83850 Answers
SOURCE: 02 impreza wrx problem with turbo PLEASE HELP
This is not the turbo it is the over-powering the clutch, it happens in 5th because that is when most worn clutches slip, it is the biggest load, replace your clutch.
Posted on Oct 31, 2008
stug_57u
  • 99 Answers
SOURCE: makita LS1013 miter saw motor runs very slowly
Could be a bearing problem. If the bearings are dry and seizing up they will hinder the motor speed. Alternatively, if they are worn and allowing lateral movement in the motor the armature will rub against the field windings when it all magnatizes (sp?). I would investigate bearings before electrics. Hope this helps, good luck.
Posted on Nov 29, 2008
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
aborcass
  • 2651 Answers
SOURCE: Whirlpool dishwasher chopper blade
you can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
Posted on Mar 31, 2009
How to i fix my swamp cooler
sounds like a alignment problem. take a straight edge between pulleys. also start out with new belt. be sure your using original belt number.
Aug 04, 2015 | Champion Cooler 4000 CFM Down-Draft...
Had repairman fix my disherwasher few days ago not draining. Now it's noisy while washing which was quiet before
Look around the bottom of the tub for foreign material, like a knife, spoon, nut or bolt.
I think if the repairman had "done it", it would have acted up immediately.
Also, look for anything sticking below the basket that might be interferring with the washer arm that spins around, too.
Jul 20, 2014 | KitchenAid Dishwashers
Bosch dishwasher makes noise while draining
If your model has a separate drain pump? You may have something caught in the pumps impellers.
Dec 04, 2013 | Bosch Dishwashers
Ge spacesaver wcse4160b
follow the steps and fix it. God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replace the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To chech and replace the motor coupler watch .
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be dissasembly to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types replace the pumps or inspects
Jun 19, 2013 | Televison & Video
Kenmore 2708 washer has a rubbing noise during spin
see this causes and fix it. God bless you
Level
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 25, 2012 | Kenmore Oasis HE 27082 Top Load Washer
Washer fills and just hums in all settings
see this causes and fix it God bless you
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Sep 25, 2012 | Washing Machines
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Noisy pump
Obviously, this unit has a warranty. Are you packing the coffee too tightly? Run the unit without any coffee and see if the vibration is still there. If it is, get it fixed. If not, modify what you're doing.
Nov 02, 2007 | DeLonghi BAR 140 Espresso Machine
Dishwashers Logo
23 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
