Question about iRiver PMP-140 Digital Media Player
Iriver pmp-120 boot failure
I have an iriver pmp-120 when I turn it on it comes up with a boot failure screen. Do you have a fix for this item and if so how much does it cost to get fixed?
  • 6 more comments
  • bambinosslav Nov 16, 2008
    The advice that I got from Guru did not help at all. I had windows run a system error check on the player and that also did not help.
    The message in the screen is Boot failure
    I have already done that 3 times with no improvement.
    I do not know where the installation cd is. Now when I open the player under my computer, there is nothing showing on the player.
    I do not have the installtion cd, so I went to shamrockman.net but there wasn't anything to download.
    Iriver does not have any downloads available for the pmp-120 nor the 1.23 firmware.
  • bambinosslav Nov 17, 2008
    Ginko,
    That worked! My iriver has the firmware version 1.23, but the website you sent me to did not have a 1.23. I tried the 1.25 first and it did not work, so I tried the 1.24 version and the player is up and working.
    I just wanted to say Thank
    It worked great.
    I did repost to let you know the slight changes I had to do to get it to work. I also emailed your because I could not get back to your solution to accept it, but I had left the page open with your solution and when I realized that I accepted your solution.
    Thanks Again
    Sergeant:
    Champion:
  • 283 Answers
HI,
Your Iriver pmp-120 boot failure problem needs to be restored its factory setting. It is a software failure. Your iRiver's Media Utility dont have a restoring setting. I suggest you to go to iRiver service center to restore your media player...Please dont rate me if not satisfied with my suggestions.... Thank you for using fixya..
Posted on Nov 17, 2008
  • 728 Answers
Go to this website and read and do the stuff it tells you to on how to fix your pmp player: http://forums.shamrockman.net/tutorials/boot_failure.php
This should help you if you follow all of the directions.
    Master:
    Sergeant:
  • 449 Answers
Hi
try to locate the reset settings!!
    Brigadier General:
  • 6,966 Answers
Initially, the message "BOOT FAILURE" is significant. It indicates that the unit could not even start itself properly. This is a software problem, more specifically the firmware. If performing a reset (pinhole on the top) does not resolve the issue, then perhaps what is required is a flash or firmware update. Pls try:
  • download/update the firmware, pls start here;
  • Restart the iriver in emergency mode;
  • Plug it into your computer;
  • turn it on and hold the O button (enter button);
  • Click on the firmware button;
  • reformat the player.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
    Scholar:
  • 181 Answers
 dload the version you want to run.  PMP will show 1.23 , now run 1.23.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
  • 1 more comment
  • fixyy Nov 16, 2008
    download it from:
    www.shamrockman.net
    just copying the files to your PMP Player will NOT work.
    delete ALL (7) of the system files and folders.
    1.) BMP folder
    2.) etc folder
    3.) system file
    4.) (4) "Version-[0x..... " files..
    So there are (7) items I has to delete. Once deleted go to the folder you saved the dloads to.  click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on.Please let me know  if this helps..
  • fixyy Nov 17, 2008
    click---- tutorials and guide ----- on the main page of
    http://www.shamrockman.net/
    and there u will get the option of 1.24 instead of 1.23 for download.
    download 1.24 and follow the same procedure which i gave u .
    note: 1.24 will support your pmp
    Sergeant:
    Champion:
  • 200 Answers
Hi
Reset the system and then then try it..
thank you
    Sergeant:
    Champion:
  • 347 Answers
Hello bambinosslav, can you pelase tell when what is the message that comes up on the screen?
  • Santiago Vallejo
    Santiago Vallejo Nov 16, 2008
    The failure boot is caused beacuse vital files are missing in the PMP.
    You have to conect it to your computer are reinstal the software.
    (do you still have the isbatlation CD?)
  • iRiver Master
  • 19,396 Answers
Try pressing the reset button that is located at the bottom of the player near the hold switch.
  • 1 more comment
  • Ginko
    Ginko Nov 16, 2008
    Sorry, I was away.
    Follow carefully the instructions on the following website.
    That shoud fix your I river, if it does not work the disk is damaged.
    Here is the fix: Boot Failure
  • Ginko
    Ginko Nov 16, 2008
    Sometimes just downloading and following the procedure in Boot Failure does not work, because the system files cannot be overwritten, in this case follow the additional instructions here to delete manually the system files.
  • Ginko
    Ginko Nov 17, 2008
    Good to know.
    The link posted alltogether make a good solution and firmware source to fix the boot failure on Iriver.
    I think I will publish a complete metod to fix this in tips and tricks for Iriver.
    Thanks for the additional update.
    If you sent me an additional mail, that had probably been lost in my few thousand mails in arrear.
    Thanks.
IRiver Screen
You'd need to find someone with a dead one (dead for some other reason) you can then canibalise.
The LCD screen could be replaced you just need to find an appropriate alternative. eBay or web search would probably find one, But you'd need to find the spec of the original first.
Iriver don't repair but do they sell spares?
Jun 12, 2008 | iRiver PMP-120 Digital Media Player
Iriver pmp-120
Boot failure or just nothing?
Boot failure would be the hard disk.
Just nothing would indicate that the system board is dead.
You don't mention using the mains power adaptor.
Mar 15, 2008 | iRiver PMP-120 Digital Media Player
Boot failure
1st go to Ihttp://www.shamrockman.net/ and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Thanks..
Jan 08, 2008 | iRiver PMP-120 Digital Media Player
Boot failure
1.) BMP folder
2.) etc folder
3.) system file
Thanks..
Jan 02, 2008 | iRiver PMP-120 Digital Media Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
PMP 120
how to rectify boot failure pmp-120
Oct 02, 2007 | iRiver PMP-120 Digital Media Player
Just a blank white screen on my iriver PMP
I have exactly the same problem with my PMP 120, would love to know how to fix it but will not stay on long enough to run it through my computer, I'm frustrated as I have a lot of data on it.
May 20, 2007 | iRiver PMP-120 Digital Media Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
Boot failure
Dead Hard Drive. Thats all i can tell you. Did you hit a huge pothole or drop it today? With the way firmware is today you'll juest need to send him in. Sorry to say it, but that's the solution! thanks! Let me know of any followup needed
Apr 28, 2007 | iRiver PMP-120 Digital Media Player
iRiver PMP-140 Digital Media Player Logo
322 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
