Question about AEG Lavamat 88840 Front Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
The washing machine is not blocked and does not have too many suds and it pumps out water OK but when it comes to fill up for the rinses it carries on filling until the water overflows from the top of the washer. This is not suds just plain water. If you put it on spin or empty then it will spin and empty, but floods when it fills up as if it doesn't know what the water level should be. Sometimes it says F1 then after a while continues on with the cycle.
  • Polly Parkinson Dec 12, 2006
    Its E number is 605 649 123 and although it is 10 years old it was very expensive and has always worked really well in the past. I need advice on whether is sounds repairable please.
    President:
  • 1,462 Answers
Fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Posted on Apr 10, 2007
  • douglas smith Apr 10, 2007
    even if a pressure stat is needed, part is reasonably cheap so worth fixing.
Water leaks out of soap tray when filling
Take the soap tray out of you washer. You probably have to press down a tab while pulling it out.
Look inside where the tray was and see if anything is blocking water flow.
Then take the tray apart, wash it, reassemble it, and slid it back in..
Jan 02, 2017 | Washing Machines
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
How do I get rid of the soap suds coming out of my new bathroom sink overflow (the hole at the front of the sink)?
Your sink drain is partially clogged below the overflow drain so suds laden water is backing part way up that tube discharging suds out the overflow opening.If you have a push-pull built in stopper that's probably holding up a clog just below. Clear the clog, soap suds act like they should.
Nov 05, 2014 | Cars & Trucks
I have a AEG lavamat 6955 sensorlogic front loader I had the motor changed 5 years ago. The washing machine still works but the drum is tight and does not turn. Even when the machine is off. It is...
Could be that the Inner Drum Spindle is broken, this is a 3 arm spider-ish bracket that holds the inner drum. To test this theory, see if you can lift the inner drum up & down from the door side, you will be able to feel if it is broken.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | AEG L86800 Front Load Washer
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
Water coming out of detergeant tray when filling. water can be removed from machine if drain is selcted manually as a programme
IS MACHINE OVER FILLING OR IS WATER JUST COMMING OVER TRAY IF TRAY TRY CLEANING TRAY AS MAY BE BLOCKED ALSO CHECK WHER TRAY CAME OUT FROM FOR SOAP POWDER DEPOSITS
Jan 01, 2010 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Please help
your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer1.gif stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Feb 07, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72640 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Feb 10, 2007 | LG WM-2277HW Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
434 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
