Question about Toshiba DRW2 DVD Recorder
Error code Toshiba D-R250SB
I get error code Ec0532 - can not under stand why or how to resolve it - any clues?
I can not finalise previously recorded discs nor start to record new ones
Help!
  • geoamancy27 Feb 23, 2009
    I'll think I'm recording something, but at some point, it goes to a error message saying that there's disc error and that it can't be recorded. I'll wait for a while with the whole thing stuck, then will unplug and its saying its repairing. There will nothing there when I try to play.
SOURCE: Error message
Try using suggested DVD media as suggested by Toshiba. DVD-R, or -RW, 4-8x, Fugi, Verbatim, or Kodak. When writing DVD, include All pretest. Seems to work for me so far.
Posted on Mar 04, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
Posted on May 30, 2009
SOURCE: Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Posted on Apr 17, 2010
SOURCE: toshiba dvd recorder D-R17DTKB error E4 54037380
has stopped acceping dvd rw +or-discs?
Posted on Jun 20, 2010
Toshiba estudio 181 gives error code c44 any button not working
C44 indicates fuser problem.
Try perform 08-400, set to "0" to reset the error.
If persist, u need to check the themistor & heater lamp on the fuser unit.
Oct 02, 2012 | Toshiba e-STUDIO181
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
May 28, 2009 | Toshiba DRW2 DVD Recorder
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
DVD recorder
TO RESET PRESS >> BUTTON FOR 5 SECONDS OR MORE (WITH NO DISC IN)
Apr 02, 2008 | Televison & Video
Finalising
i bought a camcorder from currys model vp dc 172w back in october. i took it to las vegas to record my wedding. its recording fine but i cant finalize the disks. iam folowing the instructions from the book. on 1 disk its trying for about 30 seconds then is saying disk error. the other disks i cant even get them to start running. can you help me please.
Oct 30, 2007 | Samsung VP-DC161 DVD Camcorder
Toshiba DRW2 DVD Recorder Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
