Question about Whirlpool SB160PEE Gas Single Oven
Oven not heating
Gas oven not heating self cleaning not working temp.115 only magtag 20 years old. location of part thanks
  • Whirlpool Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Sep 30, 2010
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Display went blank during the self cleaning cycle
heatman101
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
Oven too hot!!
sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool SB160PEE Gas Single Oven Logo
123 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
