Question about LG U8150
LG U3880 No Signal
My LG U3880 has lost its signal and no matter what I do Icant find it again, I have moved areas, I have manually searched for a signal but nothing works. What can I do to get a signal back (Im on the 3 network and works well with my partners phone so its no the area we are in) It has been like this for a few months now, Im am stuck iwth a phone I cant use.
    New Friend:
  • 22 Answers
Is this a 2nd hand phone? If so it may have been barred from previous owner.This happens a lot more then people think.
Posted on Sep 28, 2017
Buschchris1
  • 474 Answers
SOURCE: Stuck in Emergency mode
Open the flip part, hit the " O.K" key and hit 0 ( zero)
The code is al zero's.
Be carefull in here, go through the munues and options and looks for the reset phone option and select it, it should reboot the phone and return all the settings to default.
You could also try dialing *228 and send, see if it updates
I havent done this in a long time so i cant tell you how to exactly navigate the service menu because my envy broke and i cant use the keypad.
But there are options to set it to ( 1x ) on the roaming and other ways so that it only looks for Home based towers. You can set it to " Home Only " also, if it doesnt work, set it back to Dual.
These are just some options to try i dont know if it will work as you may have a hard ware problem and its nothing to do with the software.
Good luck.
Posted on Feb 20, 2008
  • 29 Answers
SOURCE: no signal when not in town
try this..
just press 2945#*# then factory reset.
then press 2945#*# again and choose world phone./ your band.
Posted on Jun 10, 2008
SOURCE: LG 8700
HAD THE SAME PROBLEM NOW ON MY 3 RD NEW PHONE LG IS A PICE OF SSSSHHHHHTTTTTT
  • 4 Answers
SOURCE: now i have no network from 3
lgu400code
Posted on May 13, 2009
noname2
  • 109 Answers
SOURCE: My phone froze up while in a no service area and
Did you try turning it off and back on? Try removing the battery and keeping it out for at least ten minutes, then putting it back in before you start it up again.
Posted on Jun 07, 2009
I bought aRCA air ultra thin multi directional indoor HDTV antenna,I cant get this to work with my tv, a 32mf330b/f7 no matter what I do no matter how many times I run the autoprogram,can You help.
Indoor aerials are exclusively for areas with a strong signal and the way digital tv works a good signal is essential.
I expect the signal where the aerial is sited has a poor signal strength and a high gain outdoor aerial will be needed. I suggest you have a look around and check what the neighbours are doing but bear in mind the signal strength in built up and fringe areas can be the radio equivalent of micro climates where moving a few yards in any direction and you could either be freezing or growing pineapples.
If you can take your tv to a good aerial and do a retune and store the found channels you might be lucky and discover your indoor aerial might receive a few channels well enough for viewing.
Mar 19, 2017 | Ultra Televison & Video
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
My LG thrill suddenly lost it's signal, and now
I had the same issue. A factory reset fixed it.
Dec 26, 2011 | LG Cell Phones
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
I have 2 bars icant watch movies poor signal dill_pamela@yahoo.com i have adell mini inspirion with t- mobile web connect
If you use mobile web as a server, shop around as if T-Mobile doesn't give a good signal in your area, Orange or Voda might.
Nightmare, I know!
Jan 01, 2011 | Dell Computers & Internet
The battery life of my ku990 is abnormal
The two main causes of battery life loss that no one thinks of are:
backlight settings (if you don't really need the backlight to stay on for 60 seconds after the last button press, lower it. this is a huge waste of battery life and it is easily changed in the settings menu of nearly every phone i have seen)
poor signal areas (when you have low signal, you phone wastes its battery life searching for acquirable signal. if it is unable to locate the signal, it will continue to search. this search uses up your battery life quite rapidly)
Jan 02, 2010 | LG KU990 Viewty
My phone froze up while in a no service area and is still searching for a signal
Jun 05, 2009 | LG RUMOR Cellular Phone
No signal when not in town
try this..
Jun 10, 2008 | LG C2000 Cellular Phone
Lg 42PX4dv PC connection
I think the problem is the screen resolution and size of your pc is not matching the resolution size of your tv or is not compatable at the size you have it on or you may have to change to 4:3 ratio from widescreen. In your manual it will tell you the resolution sizes that you tv uses. You would probably be better also using the VGA to DVI lead, thats if it came with the tv (it does in the UK) as it supports higher wide screen resolution, whereas VGA will only support 1024 x 768 or there abouts.
May 19, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG U8150 Logo
111 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
