Thanks. :D
It's not worth repairing. A new charger may cost less than $15.
Here below is one that you could consider.
http://www.chargerbuy.com/acer-aspire-one-532-ac-adapter-19v-40watt.html
It's best to buy a new one, otherwise you might burn the house down or electrocute yourself or the dog. They can be purchased for less than $10 on eBay. Just put in the search Acer Aspire One 532h AC Adapter and you will see tons of them. Select the tab to Buy It Now to see the ones you do not have to bid on. Sort the items Prices Low to High.
http://www.ebay.com
The link below is one I selected that costs $5.45 and free shipping.
http://www.ebay.com/itm/AC-Adapter-for-Acer-Aspire-One-532h-D255-D255-2509-D255E-D257-D260-NAV50-PAV70-/220970539521?pt=Laptop_Adapters_Chargers&hash=item3372deda01
Go to www.ebay.com Type: make and model of laptop refine search to power supply, better to replace adapter.
SOURCE: i have acer aspire one 532h with original window xp.
Turn off the system , Turn it back on , as soon as it turns on hold down the Alt Gr and tapp the F10 Key without stopping , you can see windows loading file ,it will take you to recovery console , select restore system to factory defaults
SOURCE: trying to add ram memory to Acer Aspire One 532h.
Sorry, it is not expandable up to 2GB. The Computer supports RAM up to 1 GB only..
Click here to view the specification of the Computer.
SOURCE: my acer aspire one 532h-2db
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
Extract the files from the downloaded zipped BIOS file.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
Ensure that the AC adapter is plugged in.
Insert the USB flash drive into a USB port.
Press and Hold down the Fn and the Esc keys together and press the power button.
When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
After the keys have been released the power light will start to blink.
During the BIOS update process the display will be blank.
Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
SOURCE: my acer aspire one 532h blank screen when turn on
Its may b ur vga fault so repace ur vga and chek it
