Question about E-Machines T5048 (7136) PC Desktop
Emachine t5048 slow from login to desktop access/clock lag spikes
In past 3 weeks my computer has gotten progressively slower from login to desk top access...takes almost 45-50 mins now.
Have run several recommended scans from Windows Live One Care to rule out virus.
Have upgraded svc pack from sp2 to sp3.
Have been noticing that there are continuous and frequent lag spikes in clock time which I believe are freezing up processes temp until clock catches up to correct time.
Noticed when installing addtl memory that there is a batter inside hard drive...could this be the problem?
Also noticed that I can no longer here fan running...could this be the problem?
Emachine will be 2 yrs old at Christmas 08.
Thank you for your help!
  • Anonymous Feb 21, 2009
    I have one of these POC T5048's. Always slow to startup even when brought out of hibernation. My sister has one too. Same problems. Have a look on internet. These have bad reviews. Not very fast considering it's a P4 / 3.06 GHz. My 7 year old Sony VAIO runs circles around the T5048 and it only has a 2.0 GHz AMD Athlon processor!! Wish I would have done my homework before purchasing. I just restored it to original condition with the factory disk and just ordered a 1GB memory stick to add to the 512MB it came with. We'll see if this helps any.
Let me tell u what all you have to do is go to your bower type in ccleaner this program well eliminated all you trouble then download it and install it after installing it open it, its very simple so u'll understand it very easy now click on run ccleaner then registry after cleaning the unnecessary junk u had on ur pc select tools, startup and untick all programs that wouldrun at startup u may leave just ur virus progam only to run and your done one more thing you can selected the ccleaner to run at startup also that it.
Posted on Mar 30, 2009
  • E-Machines Master
  • 4,338 Answers
The chatter in the hard drive could mean that it has a problem and it may be on it's way out.
The Fan being out is definitely a serious problem and the unit should not be used till the fan is replaced.
Once you correct the fan situation, you need to update and run your Anti-virus program. Download CCleaner, WinPatrol . Install and run them also.
I had a client's PC that was running slow and it was because of Windows Live One Care. I removed it and cleaned it up and got it back to normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 16, 2008
No signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
May 20, 2012 | eMachines T5048 PC Desktop
How do i reset my emachine t5048 to factory setting without the windows boot disc?
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Oct 17, 2011 | eMachines T5048 PC Desktop
What type of ram do i need to use?
Your eMachines T5048 PC Desktop uses RAM of specification DDR400 which is also called PC3200. DDR Stands for Double Data Rate.
Your computer is expandable to a maximum of 2GB
Take care!
damnor01
Jun 09, 2011 | eMachines T5048 PC Desktop
Will my emachine t5048 support AGP or PCI-Express? what video card should i buy to get the most out of my system?
Your system supports PCI Express x16. So look for a compatible video card which should atleast have 512mb of video memory.
Jun 06, 2011 | eMachines T5048 PC Desktop
My desk top comp was purchased in 09, the last couple of months it has kept getting slower and slower, green screens will apper and I will have to restart the computer. this past week it has been...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot login to windows and
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
Next time you login to windows your issues will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Apr 11, 2011 | Computers & Internet
I need to know if my T5048 dsktop computer is a high density or low density for upgrading memory
Take a stick of the old memory with you to the store and they can identify and get you what you need.
Oct 17, 2010 | eMachines T5048 PC Desktop
Have issues with desktop freezing up and or slowing after I changed power otions. It used to cut out all together. It is an Emachine T5048
You should check your fan isnt clogged up with anything.
If its still slow it may be a virus problem. Scan your computer .
If this still continues then re-install windows
May 20, 2010 | eMachines T5048 PC Desktop
How to put the recovery partition back on the emachines t5048
As far as i know the only way is to run the restore disk from emachine that is for your model computer. (it usually wipes the computers hard disk in the process.)
the link below will take you to their support site for drivers.
on that site look for eMachines Recovery Media Purchase Program and you can see about ordering the recovery disk that you need.
http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
Sep 15, 2009 | E-Machines T5048 (7136) PC Desktop
My sound card is not installed on my computer because i did the recovery. where can i download one? it's a eMachines windows XP T Series T5048
Here's a link to the Emachine support page for your model. Scroll down to audio section and you should be able to download your sound drivers. If the sound still doesn't work after doing this download the chipset drivers and then try downloading the audio drivers again. Sometimes you need the chipset drivers first before the audio drivers will work. http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
Jun 14, 2009 | E-Machines T5048 (7136) PC Desktop
E-Machines T5048 (7136) PC Desktop Logo
503 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
