Question about Dell Latitude D600 Notebook
Wireless not working
I have a Dell Latitude D600 and sometimes my wireless card will not engage. Meaning the computer says that the wireless card is non existent. The solution i have found to this problem is when the computer is fully booted and the card is not found I turn off the computer, wait 60 seconds, reboot and wait to fully boot, if the wireless is still not working restart the computer, in the first screen you have the option to press f2 and f12, you press f2 to enter setup, you then go to the expandable area and keep flipping through all the pages until it says the wireless card is there, then exit the setup and log in and it works. I believe i have a dell 1395 mini pci wireless card. If anyone could help me so I don't have to go through these long steps it would be greatly appreciated.
  • 1 more comment
  • dirtracer69 Nov 16, 2008
    yes i have. it still does this.
    yeah i have to go into the registry and flip through the pages until it says the wireless is turned on.
    ok thanks for trying. i will be getting a new laptop soon anyway. an inspiron 1525 fully loaded.
  • 33 Answers
Have you downloaded the new drivers for the card??? Sometimes a driver can fix this issue you are having..
Posted on Nov 16, 2008
  • thejohnsonsn Nov 16, 2008
    I would think maybe somethign in the registry on boot up or check bios to make sure sees the card there and set properly
    yea then i would say the only real way to fix is either to reload OS from scratch or if you know what your doing in XP in run a repair of the OS
Where is the wifi switch on my dell latitude d600
Hi!
To Enable wireless adapter for Latitude D600 Press Fn+F2.
Hope this helps.
Mar 17, 2011 | Dell Latitude D600 Notebook
How do you turn on wireless internet on a dell latitude d600
In a dell computer the FN+F2 keys will help to turn the wireless on .. Nut you have to press and hold the FN key and then press the F2 key once,,
Even then if the wireless is not working then you have to reinstall the drivers for the dell wireless card..
The issue will be surely fixed
Dec 06, 2010 | Dell Latitude D600 Notebook
I need a wireless card for dell latitude d600
any wireless card in the pcmcia slot or a usb will work. If it came with wireless on the board it may be off check this first before spending money.
Nov 28, 2010 | Dell Latitude D600 Notebook
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
My dell latitude d600 is not recognizing any wireless connections. I believe the switch is at top of the keyboard and it doesn't seem to be working. Any advice
if it is not seeing any wireless networks, the wireless card may be defective, try having it tested, or check the device manager to make sure the drivers are installed correctly for the wireless network adapter
Jun 27, 2009 | Dell Latitude D600 Notebook
Where is wireless switch located on latitude d600
press function (Fn) then the F2 key. but if ur wireless card was not properly installed this will not work...
Apr 12, 2009 | Dell Latitude D600 Notebook
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Bad Wireless Connection
This is usually caused by a driver glitch. From the device manager, uninstall the drivers for the wireless, then reboot. The machine will find and reinstall the drivers. If the problem persist, the take the card out, clean the connections, and reinstall it. It's located under a panel on the bottom of the machine. If it still won't work, then you need to replace the wireless card.
Jun 26, 2008 | Dell Latitude D600 Notebook
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
Wireless card not recognized
Make sure you are using the latest driver and software for the card. If you haven't already done so, I would also suggest trying the card in another computer, and a known good card in your D600, to see if the problem stays with your computer or follows the card. If it follows the card to another computer then it is most likely a problem with the card itself. If other known good cards also fail in your D600 it might be something with the D600 card slot. If the slot is the problem then I would recommend contacting Dell tech support. Larry Dell Customer Advocate
Apr 11, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
122 people viewed this question
Alun Cox
